Old 07-07-2009, 04:10 AM   #1
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
Bad Battery?
so out of no where ive noticed my car chugging to start
im think ahh, i must have left a switch on no biggy, it started and i check the switches and nothing so thats kinda odd
drove around the whole day parked the car came out tonight and it was chugging again to start
so i checked with a meter and it was at 13.4 running but as soon as i turned the car off it was dropping fast down 12 then 11 and this is like watching a countdown
first i thought maybe the alternator wasn't charging right but when i start the car again it goes back up to 13-14 range so the alt is running fine
could the battery just take a dump like that? worst part is the car has like 36,500 on it now so its just out of warranty...
http://www.4055design.com
Old 07-07-2009, 08:00 AM   #2
Brian
Brian's Avatar
Have you checked the indicator on your battery? You can take your battery to an auto
parts store and have it tested. Sometimes they can just go bad.
Old 07-07-2009, 08:51 AM   #3
try turning it to "ON" for a few sec before you start cranking. 11-12v is normal for a battery when the car is not started. there is a reason why the battery says 12v anyways.
if it drops below 11, your car shouldn't even be starting.
Old 07-07-2009, 11:27 AM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Time for a new battery.
Old 07-07-2009, 11:34 AM   #5
kustom play
Drives: 07 liftback
yea im taking it in to be tested today
im just a little mad it happened like 500 miles out of warranty
Old 07-07-2009, 01:49 PM   #6
RedRide
RedRide's Avatar
If the only problem I had after 36k is a bad battery, I would consider myself lucky.
A battery is basically consider a "wear" item like brakes or a clutch and their life span can vary considerably.
Anyway, if your battery is bad consider getiing an "Optima red top"
I have one in my Celica and really love it.
For a cheaper soloution got to Auto Zone and get a "Duralast" battery as it is also very good.
The Optima and the Duralast are both made by the same company, "Johnson Controls"
Old 07-07-2009, 03:53 PM   #7
kustom play
Drives: 07 liftback
yea I took it in to autozone and the battery was bad. I picked up a duralast red top
i have a duralast yellow top in my mr2 and loved it so figured i would go with duralast!
Old 07-15-2009, 10:00 PM   #8
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
Whats the price range like on new batteries?
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline   Reply With Quote
Old 07-16-2009, 11:58 PM   #9
kustom play
Drives: 07 liftback
like 80 bucks for a good one
Old 07-17-2009, 02:45 AM   #10
yaris-me
Learn to Relax
$56 at Costco.
Old 07-17-2009, 03:03 AM   #11
YarisSedan
Drives: 08 Yaris Sedan
awwww now would be the perfect time to upgrade to a braille battery
How Long Should an Original Battery Last? molinee DIY / Maintenance / Service 127 11-29-2015 10:26 AM
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 08:38 AM
