Old 07-08-2009, 12:32 AM   #1
Morgan
Morgan's Avatar
Drives: 07 MM LB
A/C vibration from supercharged engine?
Curious is any Blitz owners have noticed a vibration at idle with the a/c on? The car still blows cold air and idles normally, but there is a very noticeable shake transmitted throughout the car
Old 07-08-2009, 01:52 AM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
lol. Morgan, almost every blitz owner has experienced it. It will idle rough, then smooth out, then circulate again and idle rough (process continued...). Correct? Ofcourse this is all happening while at a idle.
Nobody has figuired it out. But so far, almost all blitz owners are experiecing this.
Old 07-08-2009, 02:07 AM   #3
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
yeah it annoys the hell out of me, the noise is coming from the compressor itself
staypuft is offline   Reply With Quote
Old 07-08-2009, 07:05 AM   #4
s3r3nity
traded_my_mk1_for_a_yaris
s3r3nity's Avatar
Drives: Boosted Sleeper
same here, at idle with a/c on .... quite annoying.. i noticed that with the hood opened, trying to figure out where it comes from, if i tug on the alt upwards the sound goes away it may have something to do with the bracket? will have to test a few things to figure it out..
s3r3nity is offline   Reply With Quote
Old 07-08-2009, 01:36 PM   #5
Morgan
Morgan's Avatar
Drives: 07 MM LB
Well although it seems to be a common problem, at least I'm not crazy thanks guys!
(If its any consolation its coming directly from the a/c compressor, it shakes and then the belt shakes...)
Old 07-11-2009, 01:49 AM   #6
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
First one to isolate and correct this problem should get rewarded somehow. I don't like the thought of something rumbling like that.
Old 07-11-2009, 02:26 AM   #7
1NZYaris1
1NZYaris1's Avatar
Remove the S/C , i win
sorry i am just jealous .
Old 07-11-2009, 03:55 AM   #8
Morgan
Morgan's Avatar
Drives: 07 MM LB
Agreed
I like how I added $3k+ worth of parts and countless hours of install and setup yet it sounds like a cheap piece of crap while idling at a light....
Old 07-11-2009, 12:52 PM   #9
PETERPOOP
PETERPOOP's Avatar
lol. i think it's the God reason.
Old 07-13-2009, 10:22 AM   #10
Long and I were just talking about this the other day, lol. I'll keep my eat out for this!!
Old 07-13-2009, 07:19 PM   #11
kurokoma-kun
Drives: 2007 Yaris HB
Originally Posted by echo_hrs View Post
I don't have this issue..
...The only other thing I can think of, is the ac lines that had to be shifted to accomodate the setup, I used a bracket to help them stay out of the way...
I don't have this issue either. I can hear the compressor working but it doesn't vibrate. I did have a variety of other weird post-install vibrations but these have gone away over time.
My a/c lines are strapped down tightly also, maybe that makes a difference?
Old 07-13-2009, 07:27 PM   #12
Morgan
Morgan's Avatar
Drives: 07 MM LB
haven't tried securing the a/c lines yet, but the noise seems to mostly come from the air conditioning compressor itself? idk, its annoying but turning up the radio works for now
Old 07-13-2009, 07:41 PM   #13
LtNoogie
LtNoogie's Avatar
Good, those parts probably finally broke off and fell on the road somewhere.
Old 07-13-2009, 08:50 PM   #14
kurokoma-kun
Gaaahhhhh Long, I take it you are referring to the groovy spinner nuts I used to have on my engine cover??? Both them sumbeetches done broked off. Yeah they vibrated for a moment--then clattered down and bam! were gone
Old 07-18-2009, 02:29 PM   #15
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
mine vibrates too and i would do whatever it takes to make it go away
Old 07-31-2009, 07:58 AM   #16
Ramez
Drives: Fast
hey i'm new to this forum and i'm hear a clickin noise coming from my supercharger only when i idle below 1,000rpm but when i rev it goes away. I never used to have the noise before i fixed the alternator now its fixed its annoying as hell. If i plug it out the noise stops completely!. hope someone can help!
Ramez is offline   Reply With Quote
Old 08-01-2009, 12:47 AM   #17
LtNoogie
LtNoogie's Avatar
Do you have a Blitz? Are your pulleys all parallel to each other?
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
engine swap update Adriaan Canada 5 03-03-2009 06:21 PM
