Old 07-08-2009, 11:35 PM   #1
AlanSRT4
Drives: SRT4
Stiffer springs needed
Well around where I live with just 2 let alone 3 or so people in the sedan it rubs now and then and just has always felt to mushy for me like when you shift how you just feel it rock way back.
what at an inexpensive price could I get to lower the car a little and stiffen it up all at once. want to avoid the high cost of coil overs again on this car like I have on my other. thinking there has to be some combo of lower springs with a higher weight and maybe new shocks from a different toyota vehical or soemthing that might do it up
AlanSRT4 is offline   Reply With Quote
Old 07-09-2009, 12:37 AM   #2
Check out Micro Image. Garm sells Tokico blues and TigerTec springs. They're 4 kg front, and 3 kg rear I believe. The Tein S.Tech's would be the next stiffest at 3 kg front, and 3.5 kg rear.
Old 07-09-2009, 04:51 PM   #3
detroiter
detroiter's Avatar
I'm using the Tokico Blue HP's and TigerTec springs on my car. Once they are broken in, they are incredible. Definately a bit on the stiffer side but nothing unbearable or teeth shattering. I've had a full car and I'm still able to go over good sized speedbumps without bottoming out. And the thing handles like a go-kart. You really can't go wrong with this shock/spring combo.
Old 07-09-2009, 05:21 PM   #4
^ good information. Let me know if I can be of further assistance; glad to talk by phone anytime.
KSport springs too soft, need stiffer The Spectacle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 06-17-2009 01:39 AM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
URGENT help needed :( -DIY springs Masteraal DIY / Maintenance / Service 19 12-23-2008 03:23 AM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
