Old 09-29-2006, 03:45 AM   #1
Yarisik
Side Markers
Hi, this is my first post. Thanks for all the wealth of information on all the other posts! Has anyone changed the color of the amber side markers yet? I pulled it out and its a whole housing(glued together). I want to change the little bulb to Hyper white instead. Per the manual it says you need to change the whole housing. I am going to try to put my heat gun to it to melt the glue...hope I don't mess it up haha...I also want to drill another hole and install another bulb in there so I can turn on my lamps all the time since it only blinks when you signal. Or I can just splice into the bulb and keep the light on. We'll see.
Yarisik is offline   Reply With Quote
Old 09-29-2006, 08:21 AM   #2
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Welcome to the forum.
The heat gun is a bit messy.
Old 09-29-2006, 11:07 AM   #3
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
where would i get a replacement side marker housing?
will work for parts
Old 09-29-2006, 07:44 PM   #4
Yarisindo
Be Groovy!
Yarisindo's Avatar
Drives: S-Type Automatic 1.5L
I've always wanted to do that. Splitting up the housing is a little risky since I'm afraid water will get in. Yaris is a new car so there's still not much aftermarket accessories but who knows if you wait a little longer you can just buy the the whole cover with the bulb. Post your result if you are successful though. Good Luck.
Yarisindo is offline   Reply With Quote
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 02:40 AM
Side Airbags?? static808 New YARIS Purchase Forum 20 10-28-2006 11:31 AM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 06:06 PM
Side Markers /an observation MWill517 General Yaris / Vitz Discussion 13 07-22-2006 05:26 PM
side mirrors got615 Cosmetic Modifications (Exterior/Interior) 0 05-09-2006 01:28 PM
