Old 07-12-2009, 02:44 AM   #1
PhilD424
Drives: Red Yaris
2007 Toyota Yaris HB Handbrake
The handbrake on these cars are self adjusting aren't they? We shouldn't have to ever adjust them correct?
-Phil
PhilD424 is offline   Reply With Quote
Old 07-12-2009, 03:01 AM   #2
*MAD DOG*
*MAD DOG*'s Avatar
Wrong
My dealer adjusts it every service. I can tell when it needs an adjustment and just after one has been done.
Just so you know the tires are not self inflating and the wiper fluid won't replace itself either.
Old 07-12-2009, 03:02 AM   #3
1NZYaris1
1NZYaris1's Avatar
Wrong
mine does , or so the wife thinks
Old 07-12-2009, 03:12 AM   #4
PhilD424
Drives: Red Yaris
Wrong
Eh are you sure about that? When you back up and use the brakes on almost every car it self adjusts the handbrake. http://en.wikipedia.org/wiki/Drum_brake
-Phil
Old 07-12-2009, 07:05 AM   #5
*MAD DOG*
*MAD DOG*'s Avatar
Yes i'm sure. When I take it in for a service I need to lift the hand brake quite high. After they adjust the hand brake I don't need to lift it as high to get the same pressure.
Old 07-12-2009, 09:10 AM   #6
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Phil,
You are correct many are designed this way but in "real world" use seldem work effectively. Better to check them and adjust manually if necessary.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 07-12-2009, 12:32 PM   #7
RedRide
RedRide's Avatar
The rear drum brake will self adjust as stated.
However ocassionally the hand brake may (or may not) need adjustment to compensate for cable stretch etc.
Old 07-12-2009, 01:06 PM   #8
90tsi
90tsi's Avatar
Drives: 09 yaris
2 10mm open wrenches does the trick. just lift the center console up in the back. i always tighten mine up some so i dont have to pull 3 miles to get the brake to engage. not to mention it makes the random sliding a easier. :)
90tsi is offline   Reply With Quote
Old 07-13-2009, 11:37 AM   #9
toast
Drives: 2007 LB
The "problem" with the self adjusting rear drum brake is they only work when you back up and it takes some force to make the adjusters work. If you really think about it, how much do you back up? If you just back up 3 feet and gently touch the brakes it's just not going to work. When my rear drums start making a little squeaking I just make sure that I roll back a little further out of my parking spot and hit the brake sharply a couple of days and it goes away for a while. If that doesn't do it, then I start taking things apart.
toast is offline   Reply With Quote
Old 07-13-2009, 01:08 PM   #10
RedRide
RedRide's Avatar
This is true that you need to "hit the barake sharply" for the self adjusters to work properly.
I also develped the same habit years ago (with the cars that had rear drums) to ocasionally hit the brake a bit harder when backing up.
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
