Old 07-17-2009, 01:16 PM   #1
auxmike
auxmike's Avatar
Question Yaris has fuel pressure test built in???
Has anyone actually heard this test happen?
I can imagine this will be a wonderful moneymaker for Toyota as the hoses get older and leak as the car ages......
Old 07-17-2009, 01:36 PM   #2
Brian
Brian's Avatar
I remember seeing that when I first bought my Yaris. I've never heard it though.
Old 07-17-2009, 02:45 PM   #3
I hear it almost every night. I have to walk through the garage to go to and from my office. The first time it did it (probably the second night I had the car), I thought something was wrong with the car (and of course I hadn't RTFM yet). I did a quick search on here and found out about the pressure test.
Old 07-17-2009, 02:53 PM   #4
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i was changing my exhaust one time when that came on and i jumped out from under the car so quick...lol im glad i know what it is now.
Old 07-17-2009, 04:56 PM   #5
b_hickman11
Drives: 08 Sedan
I had this system on my 05 Taco so I would assume this is common on all of Toyota's vehicles produced at least in the last few years.
Old 07-17-2009, 08:30 PM   #6
BLH
Drives: 2007 Yaris Sedan
It also tests the evaporitive fuel system amd if you leave the Gas Cap loose. It will flag a "Check Engine Light"
Old 07-17-2009, 08:32 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
All vehicles have this now days. Evaporative system is the sealed system from your gas tank to your engine. It constantly self checks for leaks. Cause you wouldnt want a cracked evap hose leaking fumes and someone walks by your car smoking a cigarette. Typically evap hoses are made of a special material much stronger than regular heater hose. They last 15 years or more.
Old 07-17-2009, 08:33 PM   #8
BLH
It also tests the Evaporative fuel system. If you leave the gas cap loose. A 'Check Engine Light' and error code will be stored.
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Best fuel for yaris Yaris305 General Yaris / Vitz Discussion 25 01-22-2007 08:48 PM
07 yaris liftback and 06 xa test drive extenny General Yaris / Vitz Discussion 12 05-31-2006 11:56 AM
