Old 07-19-2009, 05:51 PM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Performance Chips / Voltage Stabilizers
I've been looking at some of the claims these gadgets make and find it hard to believe that I can get 50 HP and 3-5 MPG improvement for less than $60.
There is also a voltage system I was looking at, that says it improves gas mileage by 10%.
So my question is, does anyone have any of these things installed? Are they any good? Do they harm the engine in any way? Any thoughts or links to existing threads (if any) that discuss this, would be appreciated.
Old 07-19-2009, 05:54 PM   #2
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
voltage system MIGHT do something but those miracle chips are GARBAGE.....
Old 07-19-2009, 07:30 PM   #3
firebob
Drives: 09 yaris
I can’t see how a voltage stabilizer will do much but eat more amps and make more heat under the hood.
**adding**
I get it now. The extra heat under the hood helps out with the fuel mileage, but it also cuts your HP.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 07-19-2009, 09:13 PM   #4
POORSHA
POORSHA's Avatar
Drives: 2008 LB
These Ebay scientists must be better than the people at Toyota, go figure.
POORSHA is offline   Reply With Quote
Old 07-19-2009, 09:54 PM   #5
I bought an eBay chip and dissected it for everyone to see what was inside. Thread is on here somewhere.
Old 07-19-2009, 11:01 PM   #6
fmicle
fmicle's Avatar
I found it:
http://www.yarisworld.com/forums/sho...ce+chip&page=6
I am so ashamed right now
Old 07-19-2009, 11:17 PM   #7
POORSHA
POORSHA's Avatar
Drives: 2008 LB
Don't be, we all want the "free lunch". At least you were smart enough to ask before spending your money.
Old 07-20-2009, 11:50 AM   #8
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
the voltage system (read: lots of cable) won't do anything you couldn't do with $20 worth in cables yourself.
Just add a 1/0awg cable to all the connections you already have...
1:bat to ground
2: alt to bat
if you upgrade those to wires... and possibly relocate the ground point for the bat to ground you'll seel the same thing... but for less money.
you'll be adding weight tho, I doubt you'd see any improvement... even on a dyno.... but if you run a lot of electronics it'll help reduce strain on your alternator and battery.
Old 07-21-2009, 01:47 AM   #9
I know a former LB owner here lost his LB to his voltage stabilizer.
Old 07-22-2009, 04:50 AM   #10
Nico4960
Nico4960's Avatar
Drives: Yaris 1.4 D-4D
That it is a truth chip tuning... Forget e-bay it is not good quality...
And now with the "P-Tronic", the additional diesel performance chip for engine tuning : 117bhp and 244Nm
-> http://www.ptronic.com/index.html <-
Hello from Belgium Nico4960
Nico4960 is offline   Reply With Quote
Old 07-22-2009, 11:48 AM   #11
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I remember that post... but didn't really read it... Unless there are active electronics involved in the voltage stabilizer there is no reason why his toyota would mess up unless it was installed correctly.
I always thought the kits were just a bunch of small cables to increase the quality of grounds.
Old 07-28-2009, 04:30 AM   #12
etheliters
etheliters's Avatar
Drives: 07 yaris hatch
is that ptronic thing real?
etheliters is offline   Reply With Quote
Old 07-28-2009, 05:07 AM   #13
Nico4960
Nico4960's Avatar
Of course...!!!
I installed it on my car and real profit of power and torque...!!!
Old 07-28-2009, 05:23 AM   #14
Yes most diesel engines seem to have a big headroom for this kind of tuning... Friend of mine has a BMW 520d who got his chip-tuned like this and it made a real difference.
But as for us regular gas-burning folks, the options are rather limited
The Yaris Performance Primer eTiMaGo Performance Modifications 30 01-24-2024 04:26 AM
New shift knobs available from TWM Performance! TWM Performance TWM Performance 3 06-25-2009 04:24 PM
High voltage -m- DIY / Maintenance / Service 7 08-01-2007 09:48 PM
Yaris Performance Specs neohalo Performance Modifications 22 06-24-2007 08:46 PM
