Old 07-20-2009, 12:31 PM   #1
ChinoCharles
Drives: LB
Daily Driven Yaris @ 10 PSI
Looks like I get to be the guinea pig. After spending the weekend going over my turbo kit we found a torn coupler connecting the charge pipe to the intercooler. I replaced it and swapped the worm gear clamps out with t-bolt clamps and voila! 10 PSI in second gear at WOT on the stock motor. We will see if it blows up.
Old 07-20-2009, 12:41 PM   #2
Please keep your camera with you.
Old 07-20-2009, 12:47 PM   #3
ChinoCharles
Drives: LB
Unfortunately I don't have a still camera worth taking pictures with, but the guy going with me to the strip tomorrow has a D200 and is a pro photographer so I'm stoked to see those pictures.
I do have a mini HD camcorder that I will have with me tomorrow and this weekend.
Old 07-20-2009, 03:07 PM   #4
I meant keep it with you at all times.. you know... just in case?
Old 07-20-2009, 03:09 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
shoulda taken the t-bolt clamps i offered you lol
Old 07-20-2009, 03:14 PM   #6
ChinoCharles
Drives: LB
I gotcha Garm.
It wasn't the clamps that caused the problem. There was a gash in the coupler, presumably from a rock. It is the lowest hanging spot on the car, so I probably bottomed out at some point. I replaced it with something a little more durable.
Old 07-21-2009, 01:49 AM   #7
Keep us posted.
Old 07-21-2009, 02:22 AM   #8
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
boom
Old 07-22-2009, 09:22 PM   #9
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Lets take bets on how long it will take to grenade. 2 months? 6 months?
Old 07-22-2009, 10:19 PM   #10
ChinoCharles
Drives: LB
The funny thing is even if it doesn't, the Yaris still won't "handle" this much boost, because most of you have this preset preminition that it won't. Unfortunately, that is what Yarisworld is all about. Assumption.
+100 points to the first person to keep an open mind.
Old 07-22-2009, 10:24 PM   #11
amen brother
Old 07-22-2009, 11:06 PM   #12
PETERPOOP
PETERPOOP's Avatar
BOOM!
Old 07-23-2009, 12:10 AM   #13
ChinoCharles
Drives: LB
Keep in mind I saw a Yaris that ran this kit for 2 years, and yes, it STILL ran.
My theory is the clutch will go first. Mine is starting to go but starting and gone are two different things. It isn't slipping yet.
Old 07-23-2009, 12:30 AM   #14
saplaymate
saplaymate's Avatar
Drives: 08' HB
I think the stock forged rods will hold up fine, oh yeah I have been running around for over a year boosted too without problems, DETONATION is what has killed engines! get fuel management.
0 - 60 in 3 shifts
saplaymate is offline   Reply With Quote
Old 07-23-2009, 12:36 AM   #15
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Glad you're running strong with no boost leaks anymore . You should really invest in the snow performance boost cooler kit . Its a water/meth injection that pretty much eliminates all chances of detonation and lowers cylinder temps big time . http://www.snowperformance.net/product.php?pk=8
I bought this same kit from summitracing for like 300 I think
Old 07-23-2009, 12:47 AM   #16
If it isn't slipping, how do you know it's starting to go?
Old 07-23-2009, 12:51 AM   #17
ChinoCharles
Drives: LB
It isn't slipping. I slipped. I meant synchros.
Old 07-24-2009, 06:47 PM   #18
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
10 psi? On what turbo?
PSI ratings are meaningless without referencing the turbo producing it.
The Spectacle is offline   Reply With Quote
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
