Old 07-30-2009, 05:46 AM   #1
mba788
Drives: Yaris D-4d
White Smoke from yaris D-4D
Hi I am new to this forum,
I have a 2004 Yaris D-4D with 109k on the clock. There is oil in the exhaust which is causing white smoke. There is no oil or water leak from anywhere within the car. I took it to one mechanic he said it could be piston ring. Any ideas anyone? The car runs perfectly.
Thankyou for your help
Billy
mba788 is offline   Reply With Quote
Old 07-30-2009, 07:54 AM   #2
jorizk
Drives: Yaris 2006 1.5 L Sedan
Have you ever had any overheating issue? If not it can be caused by the piston ring..
jorizk is offline   Reply With Quote
Old 07-30-2009, 08:20 AM   #3
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
white smoke is caused by water.
you have a blown head gasket. check your oil, see if there's any creamy substance under the oil cap itself
Originally Posted by xnamerxx
you nailed it sir.
Old 07-30-2009, 10:55 AM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Oil smoke is bluish white. The two usual suspects for that are worn rings or valve seals.
A blown head gasket will pressurize the cooling system, pushing coolant out the overflow and making bubbles in the tank.
Old 07-30-2009, 11:48 AM   #5
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Are we talking a continuous cloud of white smoke or just a hint of blueish smoke on startup and deceleration? If its the white smoke when you change the head gasket dont forget to change the oil and filter before you start the car because your oil will be contaminated with coolant/anti freeze,not good for engine lubrication,and of course the engine cooling system will have to be flushed and refilled with fresh 50/50 coolant.
Old 07-30-2009, 11:39 PM   #6
toyota
SRacer
toyota's Avatar
Drives: Toyota Yaris 2007
Send a message via Yahoo to toyota
yeah, that is true, i blew a head gasket
in my civic, get it checked out ASAP...
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop."
- Dominic, Fast & Furious
Learn The Truth about Six Pack Fast!
toyota is offline   Reply With Quote
Old 07-30-2009, 11:56 PM   #7
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Is it white smoke or steam from the exhaust? Pull the spark plugs. If any of them are fouled with black carbon and oil then that cylinder has bad rings or valve seals.
Old 08-22-2009, 02:31 PM   #8
mba788
Drives: Yaris D-4d
It's not the head gasket there is no white emulsion under oil cap. There is back pressure from the oil cap. When I change gears there is white smoke coming, n when I accelerate heavy with high revs theres plenty of white smoke continuous at times, but sometimes it's perfect
thanks
Old 08-22-2009, 07:00 PM   #9
silver_echo
ekodrvr
silver_echo's Avatar
do both a compression and a leak-down test... that smoking issue says problem to me... once you know which cylinder is not working for pressure, find access to a boroscope to look at your pistons and valves... this way you can see if it is the rings or valves without tearing the motor down... only reason that i recommend doing it this way is because if you take it to a shop and they tear it down to check it, you are pretty much committed to the repair because of the fact that they already have it torn down...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 08-22-2009, 10:33 PM   #10
Yaris Hilton
Smile
I kinda overlooked that this is a diesel. White smoke will come from a diesel when the fuel doesn't ignite in a cylinder. Often that is the result of a compression loss, like a valve that's not sealing properly. You should be able to feel and hear roughness in the engine if there's misfiring, and that white smoke has a strong kerosene-like smell from unburned fuel.
Old 08-23-2009, 01:06 AM   #11
silver_echo
ekodrvr
well i missed the diesel part too... but i guess the compression test would help on diesel as well...
Old 08-24-2009, 10:19 AM   #12
severous01
well if you wanna do i t yourself it's cheap and easy.
get a compression tester from autozone. 20 bux for the cheapo, and about 50 for the stainless lined one that's about snap-on quality. any way, pull all plugs and disable injectors. install compression tester, start engine and mark the first puff and the 4th puff. should be about 40+ and 100+ and all 4 cylinders should be close to equal...w/in 10%.
ok....i missed the diesel part. but you still have diesel compression testers out there u just gotta remove the injector, not the spark plug.......cuz there are no plugs.
Old 08-24-2009, 10:39 AM   #13
Yaris Hilton
Smile
It's a Diesel. No spark plugs, It'll take a special gauge to check compression.
Old 08-24-2009, 10:40 AM   #14
ibizagti
Drives: Yaris 5door D4D
The problem, probably, is the turbo.
I have heard more problems with turbo in 1.4 D4D engine.
Regards.
ibizagti is offline   Reply With Quote
Old 08-24-2009, 11:23 AM   #15
Yaris Hilton
Smile
Hmmm, leaky oil seal in the turbo is a possibility.
I'm thinking this might ought to go to a good Diesel mechanic.
Old 08-24-2009, 01:41 PM   #16
06silveryaris
Drives: 2006 yaris
if the exhaust is oily and compeshion is good my guess would be the turbo
06silveryaris is offline   Reply With Quote
Old 08-24-2009, 04:41 PM   #17
jambo101
jambo101's Avatar
The only fluid that will produce a cloud of white smoke from your car is water in the combustion chamber and the only way it can get there is a broken head gasket or a cracked head unit.
Old 08-24-2009, 06:33 PM   #18
Yaris Hilton
Smile
That's simply not so about water being the only thing that makes white smoke.
I'm doing white decals on my white yaris BrazdonW Photo-Video-Media Gallery 8 06-21-2007 01:10 AM
