Old 08-04-2009, 09:45 PM   #1
Reeves360
Drives: 09 Yaris Sedan, 91 ToyotaTruck
Send a message via AIM to Reeves360 Send a message via MSN to Reeves360 Send a message via Yahoo to Reeves360
Engine Immobilizer p/n
Anyone have the Engine Immobilizer p/n('s) that you would need in order to add this feature to your Yaris?
Reeves360 is offline   Reply With Quote
Old 08-04-2009, 10:31 PM   #2
Amplifier, Transponder Key: 89783-71021
Computer Assy, Transponder Key: 89780-52061
Old 08-18-2009, 08:39 PM   #3
Reeves360
Any ideas if it's plug and play? Similar to the VIP RS3200 System? I don't mind swapping wires out of a harness to get things working I just need a little bit of direction.
Old 08-18-2009, 08:46 PM   #4
The ECM is the same with or without the immobilizer system. I believe that it's just those two parts and the wiring between them and the three wires to the ECM.
Old 08-24-2009, 08:52 PM   #5
Reeves360
It sounds like the wires might already be included in the factory harness and you could just plug in the two parts and not have to run any wires to the ECU???
I'll check into the 09 Sedan wiring diagram section for the alarm and see if this information is included.
Old 08-24-2009, 11:11 PM   #6
Just check your steering column to see if there is a black 7 pin connector sitting near the key switch and not connected. It will have 4 wires - pink, green, purple and gray.
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
After-the-fact engine immobilizer? Echostatic In Car Entertainment + Electronics (audio / video / alarm) 1 08-01-2007 10:03 AM
