Old 08-09-2009, 08:47 PM   #1
ryota
Dry Bones
ryota's Avatar
Drives: 2008 Yaris Liftback
Send a message via AIM to ryota
one more piece of help
sorry guys i know i'm asking a lot of questions. i got this stereo like 99% done, my only problem is that i wired the remote wire from the amps to the power antenna behind the HU... now my amps turn off when i try to play a cd or ipod. what wire should i use instead of the power antenna wire to get power to it when the radio is on and also keep power to it when i listen to a cd?
Ryota
ryota is offline   Reply With Quote
Old 08-09-2009, 10:38 PM   #2
Marthos
Marthos's Avatar
Drives: 07 3Dr LB
When playing a cd the power antenna wouldnt be needed so it cuts the power.
I would find a hot wire that comes on with the key.
I dont know colors but there listed in your last thread.
Marthos is offline   Reply With Quote
Old 08-09-2009, 10:41 PM   #3
Marthos
Marthos's Avatar
Drives: 07 3Dr LB
CTScott said this in your first post.
For the wiring. The following connections should be off of the blue connector:
Power - Black or Gray (next to blue)
Ground - White w/black stripe
Gray (next to pink)- Front Right+
Yellow - Front Right-
Pink - Front Left+
Violet - Front Left-
The rears are off of the small white connector:
Black - Rear Left+
Yellow - Rear Left-
Red - Rear Right+
White - Rear Right-
If that wire has no power when key is off then thats your best bet, if it has power when key is off dont use it or your amp will always be powered up.
Old 08-09-2009, 10:57 PM   #4
Gray (next to Blue) is the one you want. That is the ignition switched power. The black wire is the antenna one.
FS: Garmin GPS Unit w/ ProClip Mounts, 180mm Double Din Trim Piece IsLNdbOi Items for Sale by private party 2 08-23-2009 02:37 AM
Someone left a piece of paper on my car saying..... djgab101 General Yaris / Vitz Discussion 36 01-28-2009 01:53 PM
Some one left a piece of paper on my car saying..... djgab101 Australia 8 01-28-2009 08:42 AM
Canadian DD trim piece. Can any of you Canadian members get one? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 12-20-2008 12:52 AM
SPKRMAN is a Lying piece of shit! (Unedited) Nutzoids General Yaris / Vitz Discussion 95 06-03-2007 07:41 AM
