Old 10-08-2006, 03:12 AM   #1
jodiem
Drives: Yaris 5D Hatch YRS
Question Trip Computer and External Temperature Display
My Yaris did not come with a trip computer or external temperature display but I have noticed that the display panel under the clock has space for all these features. is it possible to activate these? is it something that can be done aftermarket or will the dealer have to do it?
Thanks
jodiem is offline   Reply With Quote
Old 10-08-2006, 09:48 AM   #2
Lafiro
Drives: 06 Yaris Sedan
I never knew this was EVER even an option. Trip computer, as in the odometer for trip a/b should be standard for any car. But as for external temp display..... I want that too!!! And hell yeah it would be hot to see that on the display panel.
Old 10-08-2006, 10:01 AM   #3
Certainly does not seem like an option here either, neither do the technical manuals in the DIY section mention anything similar!
Old 10-09-2006, 02:30 AM   #4
as400g33k
as400g33k's Avatar
Drives: 05 YRS Silver Lining Metallic
Thanks
Noticed that too. It looks like the circuitry is there, just wonder if at it needs is just the actual computer itself.
as400g33k is offline   Reply With Quote
Old 10-09-2006, 07:05 AM   #5
paultyler_82
If you're talking about the Trip A/B odometers... they're integrated into the main odometer... press the little button to switch between them... I don't think external temp is an option on em though. I'm confused as to what you're referring to exactly though... maybe if you have different gauges than us, you don't have them? Do you have a picture of the space you're referring to?
Old 10-09-2006, 05:15 PM   #6
SmellyTofu
好多人&
Drives: .
That is a LHD European dash (UK drive have RHD) but yes we have a similar cluster but each component on the opposite side to the one pictured above however we don't get the trip computer nor outside temperature read out functioning (but there seems to be provisions for this on the cluster).
Old 10-11-2006, 04:09 AM   #7
paultyler_82
I would say if the display appears to be there, there's probably a way to make it work... This is why I would reallly love to have full US, UK, French, German, and Japanese Yaris exploded parts references, make it easier to figure out what part numbers do what. incidentally, I recently saw a US exploded parts diagram for the front bumper cover and they had 2 parts shown that aren't even availiable here, to my knowledge, the "RS" grille logo and the mesh grille insert for the lower fascia opening!
Old 10-11-2006, 10:22 AM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
I do like the UKDM cluster the best of all the ones I have seen so far, plus you can switch from MPH to KPH with the touch of a button, very helpful for those of us who drive internationally...
Old 10-11-2006, 01:34 PM   #9
oooo pretty...
Still, digital displays are nice, but there's nothing quite like seeing a little red needle go round and stretching to the maximum it can reach...
Old 10-11-2006, 01:49 PM   #10
parbrook
Drives: Yaris T-Spirit MMT
UK Trip Computer
The UK Yaris has two buttons.
One on the right for Odometer, Trip A and Trip B.
One on the left for outside temperature, average speed, average miles per gallon, current miles per gallon and clock setting.
The trip computer resets every time fuel is added to the tank (or the tank is filled - not sure if it's either or both).
parbrook is offline   Reply With Quote
Old 10-11-2006, 07:40 PM   #11
Yaris-TJ
Yaris-TJ's Avatar
Drives: Yaris Sedan ST Barcelona Red
COOL!
Originally Posted by echo_hrs
Australian Yaris has a different all digital cluster, digital speedo...
(UK one shown here)
Cheers
Do you guys think this will be ever be available in the US, and that I can be installed with the current wiring? This looks great! and it's worth to spent 200~300 dls...
Yaris-TJ is offline   Reply With Quote
Old 10-12-2006, 06:56 AM   #12
paultyler_82
Well, it's been proven now that the US and CAN gauges are direct swaps, so I can't imagine that the Euro units arent too.
Old 10-12-2006, 09:31 AM   #13
grimez
grimez's Avatar
Drives: 2007 Yaris
Holy crap! I would pay to get that cluster in my dash! I guess only if it retained it's functionality though. Anyone know if it's possible to oder this cluster over in the great land of the UK and get it shipped to the US?
grimez is offline   Reply With Quote
Old 10-12-2006, 10:59 AM   #14
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
It reads in kilometers.
Old 10-12-2006, 12:27 PM   #15
parbrook
or Miles - it's selectable.
Note that the the MPG (miles per gallon) indication will not be correct for the US as you have a different gallon to ours.
Old 10-12-2006, 01:08 PM   #16
grimez
grimez's Avatar
Drives: 2007 Yaris
psh, if i really cared enough about MPG, i would calculate the difference(I'm an engineer, all i do is calculate).
Old 10-12-2006, 06:33 PM   #17
grimez
grimez's Avatar
Drives: 2007 Yaris
Upon closer inspection, I don't quite understand all of the guages on the digital cluster. Can anyone help me out?
Old 10-12-2006, 06:46 PM   #18
Yaris-TJ
Yaris-TJ's Avatar
My guess is that
left ? = is the RPM bar that fills up depending on your current RPM
Right ? = is the 1x1000 RPM, 2x1000 RPM.... 6x1000RPM notation....
I hope this makes sense...
