Old 08-10-2009, 02:18 PM   #1
jaimico
Drives: yaris advance
FROM 45 TO 50
I have 205-45-16 Ventus K104 on ET-40 (7" wide) rims in my sotck yaris sedan, I´m planning on installing 205-50-16 Kumho ECTAS AST tires on the same rims, would there be a rubbing problem, and how much could this change will affect the steering, car response if any?
jaimico is offline   Reply With Quote
Old 08-12-2009, 01:25 AM   #2
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
it depends on your drop
what kind of suspension are you running?
Old 08-12-2009, 01:27 AM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
might rub the fender liner very slightly over high speed bumps. I have the same tires and wheels, the rubbing is a non issue.
Old 08-12-2009, 11:01 AM   #4
jaimico
Well the car has no drop, and I got the tires and have them installed yesterday, and so far I have no rubbing so far, even at high speeds, or full turn of the steering.
thanks.
Old 08-12-2009, 11:40 AM   #5
why would you want 205/50R16??
Old 08-12-2009, 09:27 PM   #6
largeorangefont
Break'em off some.
Because it looks better and it about the same diameter as stock.
Old 08-12-2009, 09:27 PM   #7
largeorangefont
Break'em off some.
thanks.
You will never have an issue at stock height.
Old 08-12-2009, 09:32 PM   #8
supmet
Drives: 2007 4 Door Yaris
Originally Posted by largeorangefont View Post
at stock height.
Just pointing out that you said at stock height not stock springs. My rear stock springs look like DF210s already.
