#1 |
![]() Drives: Yaris 2007 sedan Join Date: Oct 2008
adding AUX input, Can this be done?
Hi everybody, I have the sedan 2007 with the stock radio
is there an easy way to install an aux input on this radio? Thank you! |
The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
Hmmm...maybe.
Take out the radio and check the back for AUX connection.
DIY: A/C Insulation |
#3 |
Yes, you need the Aux Jack (part number: 86190-53010). Check and see if the cable is there (from the back of the radio to the Aux jack location, below the AC knobs).
#4 |
Thanks a lot, i'm gonna check this tonight
#5 |
not working
I found the plug, I also found another thread about this so after reading all the posts I decided to test it, I made a test cable and connected it to the plug.
...nothing... pin 1 and 2, left and right audio pin 3 and 4, audio ground(jumped the 2 together) have I missed something? Thanks for the help! |
#6 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
i don't think both of those are ground. factory aux is only enabled when an input device is detected, so i'm guessing one is a signal line of some sort, more likely tied to the left audio line.
#7 |
well I tried connecting only left and right audio + audio ground, and leaving pin 4 unplugged, won't work
I also tried tying pin 4 to left audio, won't work either |
#8 |
![]() In order to activate the Aux input, AUXI (on the radio end) or AUXO (on the aux port end) needs to be connected to AGND. Once they are connected you can switch to the aux input, even without a device attached. Connecting those two pins together is a quick and dirty way of verifying that a HU can take Aux input. |
#9 |
Thank you very much for your help, but it seems my HU won't take the aux input
I jumped AGND and AUX0 and the radio won't enter aux mode guess I will have to buy an aftermarket radio but I have to find one wich has a rear aux input, I don't want a wire up front, I feed my music via bluetooth a2dp via my ego talk handsfree anyway, thank for the help, really appreciated! |
#10 | |
| DIY: Aux Input Jack Adapter | TinyGiant | DIY / Maintenance / Service | 11 | 11-10-2012 06:33 AM |
| Help : AUX input in the factory HU | Hossam | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 08-26-2009 12:46 AM |
| aux input for Canada RS 6 disk changer | jerry022 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 06-02-2009 05:30 PM |
| High pitched whine using stock head unit / aux input? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-02-2007 01:49 PM |
| aux input... | djfuji | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 01-23-2007 10:25 PM |
