Old 08-11-2009, 07:20 AM   #1
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
H4 HID Kit Bulbs in Stock Headlights
I'm just trying to confirm if the following aftermarket H4 Hi/Lo HID bulbs can fit into the stock headlights without modification.
This is the magnetic controlled bulb as oppossed to the High (Halogen) / Low (Xenon) H4 bulbs which are plug and play.
2007 Yaris RS Hatchback Black Sand Pearl 5DR MT
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 08-11-2009, 10:53 AM   #2
yup it will fit. that what i am using, but mines are little different.
Old 08-11-2009, 11:29 AM   #3
90tsi
90tsi's Avatar
Drives: 09 yaris
yea mine look very similiar to that as well. i believe mine are the O-nex or D-nex brand.
90tsi is offline   Reply With Quote
Old 08-11-2009, 04:56 PM   #4
bigsky2
Cousin Vitz
bigsky2's Avatar
Thanks for confirming :)
Old 08-12-2009, 04:36 AM   #5
bigsky2
Cousin Vitz
bigsky2's Avatar
Hey guys,
For those of you that installed HID bulbs like the ones pictured, were you able to put the headlight boot back on?
Old 08-12-2009, 06:58 AM   #6
bigsky2
Cousin Vitz
bigsky2's Avatar
Thanks Camelll
I had a single beam H4 bulb in there before, and I removed the headlights completely so I had more room to work with.
I took out the boots and looped the wires and HID bulb through the boot before securing the bulb in place and putting the boot back on. It was quite painless and didn't require cutting or modifying of the boot.
The base of the H4 magnetic style bi-xenon bulbs looks bigger than the opening of the boot so cutting it or making the opening of the boot a bit larger might be necessary.
Old 08-12-2009, 11:17 AM   #7
mine fits perfectly.
Old 08-13-2009, 04:57 PM   #8
bigsky2
Cousin Vitz
bigsky2's Avatar
Cool, thanks.
I tried to fit it and it works without cutting or modifying.
Should the base be inside or outside the boot?
The base of these magnetic bulbs move, so would it be better to have it outside the boot so it's not obstructed when the high beams are activated?
Old 08-13-2009, 05:05 PM   #9
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Do a search for Violin. His high/low H4, before his full conversion, were just like that.
He had tons of info about the wiring an so fourth.
Old 08-26-2009, 02:47 AM   #10
areithan1980
areithan1980's Avatar
Drives: 2007 Yaris Hatchback
AGT Xenon HID Hi/Lo
Well just got one installed on my car too yesteday but i decided to remove the tin metal wrapped around the bulb (shield) it self it looked like a guard or something since i thoguht maybe it doenst need it since i already got one in my OEM headlight assy. I was worried too that it wouldnt fit once i start pushing it in into the housing together with the OEM shield. Now my light is kinda scattered all over the place thinking maybe i should have kept the tin piece(shield) i dunno.
Last edited by areithan1980; 08-26-2009 at 02:49 AM. Reason: corrected some spelling
areithan1980 is offline   Reply With Quote
Old 08-26-2009, 05:36 PM   #11
areithan1980
nvm i put it back on and it works so much better now
Looking for a shop in Oregon to hook up HID light kit or whatever else you got??? wholenizz Northwest 1 08-26-2009 03:53 AM
HID kit side-effect?? ozmdd Cosmetic Modifications (Exterior/Interior) 3 04-18-2009 03:47 PM
My 6500k H4 HID Review [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 74 10-10-2006 08:19 PM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 07:06 PM
