#1 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
553.0 miles on 10.299 gallons of gas.
![]() Mixed driving: Charity, carpooling, bicycle and recyclable hauling, one rare solo commute and one trip over the Sierra Nevada mountains to Sacramento. One thing that helped was all the construction on I-80 closing lanes and slowing things down in some areas (e.g. 45 MPH for a few miles instead of my usual 55 MPH). This beats my old personal record, also set this summer, by more than 1 MPG.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
Beast
jesus
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#3 |
Drives: 2010 Yaris LB (Prev: 07 Sedan) Join Date: Mar 2009
Dude ...... that's amazing.
#4 |
awesome ive got close. 52.9
#5 |
Drives: lil red 5-door Join Date: Sep 2006
you're a mean, green (obviously!) hypermiling machine!
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#6 |
Yaris Hypermiler
Drives: 2007 Silver Liftback Join Date: Aug 2006
Nice going Brian, and many great tanks in your future.
#7 |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
BailOut,
Congrats, that's awesome. Many thanks for the hypermiling tips you posted here-it's how I got interested in hypermiling and I'm getting a little better all the time (plus my car is breaking in). I'm pleased with my mileage given my driving conditions (lots of in town and short trips) and the tips really help. I see in your fuel log you switched to 0W-20 oil-if you don't mind me asking I was curious what brand (or brands) you use? Also you noted using a grill block-any tips on what you use and/or how to construct one? With cooler weather approaching this has been something I've considered. TIA R2 |
#8 | |
Thanks for the kind words, all.
![]() Quote:
I use a grille block in the cold months in order to help the engine stay warmer without burning more fuel, and to help the engine burn fuel more completely. This is especially important as my area employs reformulated gasoline in the winter which burns a tiny bit more cleanly but puts a huge dent in fuel economy. I first did it by cutting foam pipe insulation in half and zip tying it in, but while this worked well it was time consuming and knuckle busting. Last season I simply cut 2 rectangular pieces from a roll of foil-based home insulation wrap and shoved them in behind the 2 grille openings. I put them in when daytime temps start peaking below 55F, and take them out when daytime temps start peaking above 55F.
#9 |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Great!
#10 |
Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
omg....i really need to work around your schedule when you visit Sacramento from time to time... i really do apologize for not making it out during those couple times because of work and stuff.....
I will keep trying though :) Would like to learn from the master. Congrats. |
#11 |
![]() ![]() Drives: 2008 Yaris LB 5M Join Date: Oct 2008
Congratulations Brian! Nothing like hitting a new record tank to make the day. Shooting for a 55 mpg tank now? You have the skills to do it!
My grill block hasn’t been in for months. I really think it adds a lot to aero as well as faster warm-up. Keep up the great mileage! |
#12 |
Audio Junky
dang.... I'm still battling to break 47mpg on a full tank. On September 3rd I'm supposed to drive the 470miles back home for a long 5 day weekend and go to a wedding... I've been flirting with the idea of actually rolling out of town the night before right when I get off work, and driving 55mph the whole way and just pulling over halfway home to sleep and then starting back up early in the morning. That way I'd get there sooner, and have probably a 5mpg bump in my gas efficiency. Not sure if even 55mph would get me over 47mpg.
Congrats again! |
#13 |
Drives: LB Join Date: Jul 2006
#14 |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
Holy crap. You guys that get that kind of mileage are lucky...I barely get to do any highway driving and around town I get about 31 (31.53 on first tank, 31.16 on 2nd).
#15 |
These guys do whatever they can to squeeze a mile. Google "hypermiling" or search for it on these forums and read about it. Its pretty remarkable.
#16 |
Yeah I've read a lot about it, one of my buddies drives an Aero and is pretty hardcore into hypermiling. My problem is that It's not too often I get to drive even 1 mile without having to stop 5 or 6 times in between :(
#17 |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
My Scangauge reads an average of 5 Liters per hundred kilometers under normal driving conditions,scan gauge says that equates to 46.6MPG,math was never my forte so trying to convert everything from metric values then dealing with US and imperial gallons is very confusing..
#18 |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
Brian,
Just when I think I am getting close to you with a single trip max of 54 Mpg, you go and pull that off for an entire tank! My tank averages are up from 41 to 46, but you are still setting the mark. Good show! R2D2, I made a partial upper grille block from a magnetic door sign. (the kind you see on contractors trucks) The corner radius on the sign happened to match the radius of the Yaris grille. Magnetic side out is black and looks appropriate. A hole punch and some zip ties or screws and drywall toggle anchors mount it. Cutting the sign in half and trimming gave me 2 pieces the covered the upper grille leaving a bit in the center, under the Toyota emblem, open. |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Mabey I Should Go for Low MPG Record? | doublewam | Fuel Economy Forum | 14 | 07-05-2009 02:59 PM |
| 52.60 mpg | Kaotic Lazagna | Fuel Economy Forum | 42 | 05-19-2009 01:45 PM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 04:23 PM |
| Anyone from Missouri? MPG problems inside | 4MPG | Fuel Economy Forum | 31 | 12-17-2008 05:48 PM |
