Old 08-14-2009, 04:32 PM   #1
rvdsabu
Drives: 2008 Yaris Sedan Silver
New Keyless Entry Question
I have a 2008 yaris sedan 4-door with factory power windows and door locks. Can i buy a FOB off ebay and program it to have keyless or will i have to buy an entire keyless unit off ebay or somewhere? I have been looking through the forums and there is mention of a $35 aftermarket system. The best I can find for a model # is the Valet 712T....It is a discontinued model, but there are a few on ebay right now for around $40 with shipping. Is there a cheaper/better newer model if i have to end up buying and entire unit and not just the FOBs....
thanks guys!
rvdsabu is offline   Reply With Quote
Old 08-14-2009, 05:10 PM   #2
PatrickJohnson
Drives: 2008 Yaris LB
there's not really a cheaper model, and "better" is subjective. I use the valet kit and love it. However, you should be able not only to get an extra fob on ebay that can be programmed to your car, but you should be able to get an oem one at that. It will likely cost you as much as the kit, but no installation worries...
PatrickJohnson is offline   Reply With Quote
Old 08-14-2009, 06:16 PM   #3
rvdsabu
are you saying the "guts" or the "brain" if you will.....is already installed into my yaris from the factory since i have power windows and door locks? So all they do at the dealership is program a key FOB for your car and put the extra fee on there? If this is so....why install an aftermarket brand in the first place?
Old 08-15-2009, 05:55 PM   #4
PatrickJohnson
I'm sorry, i misunderstood. I thought you already had keyless entry and had just lost the fob. I strongly recommend the valet 712T. WOrks great for me, and there is also a pre-made DIY guide somewhere on here about installing it.
Old 08-17-2009, 12:45 PM   #5
b_hickman11
Drives: 08 Sedan
I also have the 712T kit installed on my 08 and it works great. Bought it for $35 on Ebay. It has many different features that can be hooked up if you want them. I just installed the basic lock and unlock wires. Look for DanQ's write up.
Old 08-18-2009, 04:18 PM   #6
severous01
if u have the power the programming needs to be installed. and it's simple. it's in the DIY somewhere around here
just get the fob, pull a wire, open close the door...turn key...open close door, hit lock and unlock switch, replug wire and whatever else is involved...
now, as a toyota tech i had to do this twice, and it almost never worked for me. as many times as i completely followed the steps and clicks, opening and closing the doors, installing battery neg and unplugging pins from the computer harness....i had to get someone else to do it. and they even had to do it 4 times before it 'snapped' and worked.
Old 08-18-2009, 05:19 PM   #7
b_hickman11
Drives: 08 Sedan
So Toyota installs Keyless on all Yaris's with power? They just don't give the customer the Remote?
Old 08-18-2009, 08:58 PM   #8
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
I doubt that, but anything is possible. Like many others, I just recently bought the Valet 712T and installed it. There are 2 threads here with info and pictures on installing it and they were a tremendous help... no worries. Works awesome! $40 shipped off of Ebay from Bill's Electronic Gear and had it in hand in just a few days.
RUFFSTUFF is offline   Reply With Quote
Old 08-19-2009, 01:02 PM   #9
b_hickman11
Drives: 08 Sedan
Thats the way severous01 made it sound.......
Old 08-19-2009, 03:49 PM   #10
RUFFSTUFF
Not to be an ass, but it look like severous01 needs to be a little more technical as a Toyota technician...
...but if he is right then someone out there needs to give it a try (once they have an actual procedure.) Since I've already installed a Valet, there's no need for me to try it.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
keyless entry? / security? mem In Car Entertainment + Electronics (audio / video / alarm) 8 10-22-2008 01:29 AM
Aftermarket Keyless Entry - How does it affect the Warranty? aerock19 In Car Entertainment + Electronics (audio / video / alarm) 7 09-07-2007 02:11 PM
I want keyless entry!!! Lillydot General Yaris / Vitz Discussion 7 03-20-2007 10:46 PM
keyless entry question? punch General Yaris / Vitz Discussion 4 05-26-2006 12:46 PM
