Old 08-15-2009, 01:43 AM   #1
AznGouki
Metsu
Drives: NCP91 ; E36
Pulley install
Ok just doing the install on the pullies and I got the belt loose but now how do I take the 11mm nut off the crank pulley? It spins when I try to take it off. Just wondering how you guys kept it from moving.
Rich
AznGouki is offline   Reply With Quote
Old 08-15-2009, 02:01 AM   #2
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
http://www.yarisworld.com/forums/showthread.php?t=3964
Old 08-15-2009, 02:04 AM   #3
AznGouki
Metsu
Drives: NCP91 ; E36
Nevermind. Good on the Crank. Waterpump is the real issue at hand now.
Old 08-15-2009, 02:12 AM   #4
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Refer to the DIY on here, it helps. I used it for my mechanic who is unfamiliar w/ the Yaris.
It takes about 2 hours, at least my mechanic did :P
Old 08-15-2009, 03:27 AM   #5
AznGouki
Metsu
Drives: NCP91 ; E36
I looked off it too. No reference as to how they stopped the pullies from turning though. Everybody used impacts on and off probably. I'm using hand tools and a breaker bar. With a little improvisation I got the Crank done. Alternator is another story. I can't figure out how to get that pulley or the water pump pulley off at all.
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Yet another NST crank pulley install... YarisSedan Performance Modifications 14 04-06-2010 01:57 PM
DIY: Nonstop Tuning CR-Lite Pulley ChinoCharles DIY / Maintenance / Service 121 02-03-2010 06:41 AM
Probelm with NST Underdrive Crank Pulley Install thebarber Performance Modifications 1 04-05-2009 04:54 PM
Pulley Install : Central FL Sabretooth Southeast 6 04-03-2009 02:43 PM
