Old 10-09-2006, 11:01 PM   #1
Lowfront
Drives: Yaris Sedan
My damping project
Just figuerd I put a couple pics of my damping project.
This stuff is the best its Damplifier Pro from second skin audio
http://www.secondskinaudio.com/cgi-b....cgi?pg=1&p=ps
But here's the trunk done.
I finished the doors as well but forgot to get picture of them done, next time I take the doors off ill get pictures.
Lowfront is offline   Reply With Quote
Old 10-09-2006, 11:29 PM   #2
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Thats CRAZY!!!!! did u install it yourself?
Cuz i dynamated my car doors and they were a bitch to do, let alone the trunk........
Good job
Old 10-09-2006, 11:45 PM   #3
johnnyfive
johnnyfive's Avatar
well, the trunk will be much easier than the doors :)
and i second the seccond skin product line. it really is a step above alot of the other sound dampening products http://www.sounddeadenershowdown.com
Old 10-10-2006, 01:37 AM   #4
Lowfront
Drives: Yaris Sedan
No, the trunk is a lot harder then the doors. The doors you can confortably kneel to do, the trunk you need to constantly be in a horrible position, Proberly took me 5 hours total to do the trunk. The trunk has far more material to put down, and where the wheel goes, that area is a bitch to do.
Yes I did it myslef, between the doors and the trunk proberly took me 8 hours.
Old 10-10-2006, 11:46 AM   #5
xfatefailsx07
Lean Wit It. Rock Wit It.
xfatefailsx07's Avatar
Drives: 2007 Yaris Sedan - 5 Speed
So did it take 5 or 8 hours to do the trunk? Your post is misleading..
YARIS... enough said!
xfatefailsx07 is offline   Reply With Quote
Old 10-10-2006, 11:50 AM   #6
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Doors = 3hrs
Trunk = 5hrs
will work for parts
Old 10-10-2006, 11:56 AM   #7
xfatefailsx07
i withdraw my attempt at criticism..i will now retreat back into my hole, and not speak again.. haha thanks for pointing it out vodka..
Old 10-10-2006, 05:18 PM   #8
punch
punch's Avatar
yikes, how much weight did it add?
Old 10-10-2006, 05:24 PM   #9
Lowfront
Drives: Yaris Sedan
A good 40 pounds between the doors and trunk
Yes there was a bit of a performance drop
Old 10-10-2006, 07:55 PM   #10
grimez
grimez's Avatar
Drives: 2007 Yaris
Ugh, I wanted to add sound dampening, but not if its going to hurt my performance...
grimez is offline   Reply With Quote
Old 10-10-2006, 09:35 PM   #11
hasher22
Look mum no stars!!
hasher22's Avatar
take out ur spare tyre then, and damp it, that should equal the amount of weight taken off and added on.
Old 10-10-2006, 11:57 PM   #12
johnnyfive
johnnyfive's Avatar
i just dont like reaching into door skins, would rather lay on my back, and do a trunk :)
Old 10-11-2006, 12:03 AM   #13
Lowfront
Drives: Yaris Sedan
Ya thats a pain, the biggest thing for me is all the cuts you get. My hands have sooo many cuts on it from the material. It takes awhile to heal these damn things because me hands get dirty at work.
grimez: If you want to dampin your car def. do it. Don't worry about the slight loss of performance you'll get used to it after an hour. Damping your car, if done right makes such a huge diffrence in sound quality of your system and makes the ride much nicer considering a lot of road noise disappears.
Old 10-12-2006, 09:27 AM   #14
grimez
grimez's Avatar
Drives: 2007 Yaris
Ya, i will probably end up taking out the spare... im a huge audio phile, and I don't think i could live without the dampening.
Old 10-13-2006, 12:02 PM   #15
ttufrosty
Out of curiosity, how much material did you end up using for the trunk and doors? I am going to dampen both my car and my wifes (Scion Xb) and want to puchase all the materail at once.
ttufrosty is offline   Reply With Quote
Old 10-13-2006, 02:22 PM   #16
Lowfront
Drives: Yaris Sedan
80sq feet.
Thats doing it right though. You could use less.
Old 10-13-2006, 02:24 PM   #17
vodkalush
I drive a yarrrris
vodkalush's Avatar
damn, thats a butt load.
will work for parts
Old 10-13-2006, 04:12 PM   #18
ttufrosty
wow , that is a lot. It was recommende that I would only need 50sqft for the Xb, and that was the floor, doors, and hatch. So either that is wrong, or you just used quite a bit, which must make for a very quiet car.
New to the forum, introducing my Echo RS (My Project Vitz) *56K* ToyVitzRS Photo-Video-Media Gallery 5 04-25-2006 11:46 PM
