Old 08-17-2009, 07:59 AM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
brake kits
hey guys
im doing research , need to change my front discs soon , so want to get a better brake setup , what are you guys using ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 08-17-2009, 08:44 AM   #2
A lot of people like the R1 Concept front discs, same size as original, but slotted and/or drilled for looks.
Or you can get a kit for larger discs but using the stock calipers.
Or you can get a proper Big Brake Kit with larger discs and calipers, that's what I had.
Truthfully from what we see of people racing their Yaris here, the stock brakes are already quite good, maybe get a set of R1 discs, some good pads and stainless steel lines.
Old 08-17-2009, 09:53 AM   #3
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
wasup my bro !!!!!!
thanks for the imput
yeah , i was thinking along the same lines.
do the R1's make a big dif ? cause im running 17 inch wheels , thats what made me think of using a larger disc , but then again you become restricted if you want to change back to 15inch.
JDMtuner
www.jdmtuner.co.za
Old 08-17-2009, 04:34 PM   #4
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
R1 front rotors with a 17" wheel. I love 'em !! I also have the rear disc conversion. It's even more awesome !
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 08-18-2009, 01:44 AM   #5
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
NICE !!! looks really good !! did you find a big difference with just the disc upgrade to start with ?
JDMtuner
www.jdmtuner.co.za
Old 08-18-2009, 02:22 AM   #6
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
any bbk companies out there that clear 16s?
Old 08-18-2009, 03:58 AM   #7
Japanese company ATS is pretty popular here, they have kits with mini 4 or 6 pot calipers that can fit 15" (285mm discs) and 16" (305mm discs) wheels. Pricey though, count about $1,200 before shipping
Old 08-18-2009, 05:25 AM   #8
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
mmmm , got a link ?
i think i gonna do discs first
JDMtuner
www.jdmtuner.co.za
Old 08-18-2009, 05:38 AM   #9
http://www.ats-brake.com/
Wilwood also has some mini calipers, and Garm is trying to piece together an inexpensive BBK based on them
Old 08-18-2009, 08:28 AM   #10
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
shot alot bro ! yeah , will be sweet if Garm can get somthing together.
i contacted a local guy here in RSA runing a company called Vari Racing.
he makes custom big disc setups , 320mm , he recons it will cost me about 400USD for a set of discs with adapters to fit the OEM caliper , that will be a vented and slotted disc i recon
JDMtuner
www.jdmtuner.co.za
Old 08-18-2009, 08:41 AM   #11
that's not too bad! stock calipers will look a little bit dinky though But they should be up to the task if you get good pads
Old 08-18-2009, 10:28 AM   #12
1. our front stock discs are smaller than that, so it probably wouldn't fit? Or does it come with everything you need including rotors?
2. R1 concepts rotors will not improve your braking "power". Also, for the record, they come OEM, slotted, and drilled+slotted.
So the question is, do you want to stop in a shorter distance, or do you want more resistance to fade for racing, or do you want a better pedal feel so you can control the brakes better?
Pads, fluid and lines are the best start to improved braking, resistance to fade, and pedal feel.
Old 08-18-2009, 12:05 PM   #13
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
hey buddy
Thanks for the info , much appreciated.
so what would be a good disc upgrade for better , harder braking , more power.
would a big disc kit with OEM calipers , better pads , steel hoses and better fluids be enough ?
JDMtuner
www.jdmtuner.co.za
Old 08-18-2009, 12:26 PM   #14
Yep, appropriate rotors included... but like I mentioned earlier, pricey
Old 08-18-2009, 12:53 PM   #15
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
i found this part number for Rotora discs for a yaris
R441432C
Garm , can you get more info on this possibly from them there in USA , what its size , price etc
JDMtuner
www.jdmtuner.co.za
JBT/Wilwood brake kits? Gideon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 09-15-2010 01:49 AM
Big Brake Kits 1nz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-17-2009 02:45 PM
Big Brake kits for Yaris 5 door mojoyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 03-23-2007 12:30 AM
