Old 08-19-2009, 01:54 AM   #1
YarisSedan
Drives: 08 Yaris Sedan
What is a good reccomended custom alignment setup for street
So my suspention setup is as follows. TRD springs, TRD Swaybar. Megan racing front rear and mid lower tie bar set. Tannabe front strut bar and rear hub spacers 10mm. I keep my tire pressure set at 40 thats where i notice the least bodyroll and handling increase.
I am going to get a alignment next week since its been a year since i lowered the car and never had it done. I was wondering what would be reccomended to set the front toe to make the car a little more agreesive but without causing a lot of tire wear. I plan to see if ican be in the car when it is aligned to so it is calculating my weight.
Old 08-19-2009, 02:14 AM   #2
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
where are you located?
West End alignment near LA is the best place to go that I know of
Old 08-19-2009, 03:10 AM   #3
Jason is located in NorCal.
Old 08-19-2009, 11:42 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
recommended setup for street:
-1.0 to -1.5deg front camber
0 toe
and you can't align the rear without shims, so let it be
good speaker setup. ryota In Car Entertainment + Electronics (audio / video / alarm) 18 08-08-2009 07:46 PM
