Old 08-19-2009, 03:38 PM   #1
YarisOwnersDad
Is now a Corolla S Owner
Drives: 2010 Corolla S
Battery completely drained
Does anyone know if a car battery normally suffers any long term ill effects from being totally drained? It was foggy this morning on the way to work, so I had my headlights on, and when I pulled into my parking spot at work, I forgot to turn them off. When I went out at lunchtime to start the car, the battery was dead, and I had to get a jump from someone.
I wish our Yari had that automatic headlight feature, but I know we can't have everything at such a low MSRP.
Tom
YarisOwnersDad is offline   Reply With Quote
Old 08-19-2009, 03:56 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
a single full discharge should have no noticeable impact on the battery from your standpoint.
YES it does do damage
No, you shouldn't go out and buy a new bat now (unless it starts doing this very often)
Yes, try to get in a rythym or schedule so this doesn't happen again
Yes, You should trickle charge that battery overnight as soon as possible to ensure it has the best charge possible as soon as possible after you do drain your bat.
Old 08-19-2009, 03:57 PM   #3
1stToyota
1stToyota's Avatar
Tom
I'd have the battery charged [10 amps or less] fully before I drove it too much...alternators don't make good chargers; they're designed to maintain a battery, not recharge a dead one.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 08-19-2009, 03:58 PM   #4
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Don't you get that annoying yet useful long beeep when you turn the ignition off and the lights are on?
Its a Chao!!!
Old 08-19-2009, 04:40 PM   #5
YarisOwnersDad
I thought so, but I guess I just wasn't paying attention this morning.
Tom
Old 08-19-2009, 04:42 PM   #6
YarisOwnersDad
Well, I had the afternoon off for a half day of vacation, so I ended up driving the car the 24 miles home after it was jump started. Think it is still necessary to put the battery on a charger?
Tom
Old 08-19-2009, 05:10 PM   #7
sex
sex's Avatar
Drives: 09 5DR
1stToyota meant 10 volts. If you have a multimeter, check the voltage across the terminals. You want at least 10. AutoZone near me checks/charges batteries free as a courtesy
Old 08-19-2009, 05:15 PM   #8
nemelek
DWEED
nemelek's Avatar
The few times in my life where I let a battery go completely dead it has never been the same again. No matter how I recharged it. I would wait a few weeks and then go get a load test on the battery from an auto part store.
Old 08-19-2009, 06:12 PM   #9
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
no, he really didn't... your battery won't charge if the charging source is only 10v.... UNLESS your battery is below 10v. when you have a dead battery, it might only rate 6-10volts... a 10v battery has very little juice if any. the charger should be at least 13v otherwise it'll do a poor job.
A 10amp charge is meant for a quick jump start. go for a 1-2amp trickle charge, its meant to give a much fuller charge.
Charging batteries is like pour a glass of guiness. if you do it fast you will fill up the glass, but it won't actually be full, it'll be a wierd frothy mixture of liquid and air bubbles.... You'll get some, but its not really a full glass. You pour it extremely slow and you'll actually get more in your glass.
remember, batteries use chemical reactions to produce electricity, it takes awhile to get all the chemicals set up for those reactions when re-charging.
Old 08-19-2009, 06:27 PM   #10
draining it once will not totally damage your battery. Doing it often will destroy it, but well.. Btw, if you noticed your lights were one at lunch time... your battery was probably not COMPLETELY drained.
I think driving ~30mins put enough juice to the battery to not die on you tomorrow. _I_ wouldn't worry about it. but like talnlnky says, putting it on a tickle charger is best for the battery.
Old 08-19-2009, 06:32 PM   #11
YarisOwnersDad
Oh, it was drained alright. Even the automatic door locks wouldn't operate. When I used the key to get into the car and put it in the ignition and turned it, I got NOTHING. There was absolutely no response at all from the ignition, not even a feeble attempt to start.
Tom
Old 08-20-2009, 08:24 AM   #12
1stToyota
1stToyota's Avatar
Yeah, 10 amps or less. 2 amp charge could take as much 24 hrs to fully charge a dead battery, 20 amps will do it in about 4 hours. Quick charge (about 1 hour) needs at least 30 amps. Jump/Engine Start on my charger is 275 amps.
Any time I quick charge I remove the - battery cable...charging volts can go beyond 16v when charging is near complete.
2008 Scion xD
Old 08-20-2009, 08:27 AM   #13
1stToyota
1stToyota's Avatar
Tom
You probably just warmed up the alternator a bit more than usual. A trinkle charger for a few hours would be better than just getting in and driving the car again.
2008 Scion xD
Old 08-20-2009, 12:37 PM   #14
RedRide
RedRide's Avatar
My experience has always been that it you completely discharge a battery, it will recover.
However the life of the battey will be cut. How much life it will lose can vary depending on the overall condition /age of the batterey. If the battery is fairly new, you should still have years of life in in it.
Old 08-20-2009, 04:07 PM   #15
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
if you start to develop a habbit of leaving the lights on... you might consider buying a deep cycle battery when you have to buy a new battery.... Deep cycle bats are designed to be discharged and recharged many times. I ran an Optima Blue top Deep Cycle in the past and loved it... never had any problems. Deep cycles generally cost more money.
Old 08-20-2009, 04:13 PM   #16
YarisOwnersDad
if you start to develop a habbit of leaving the lights on... you might consider buying a deep cycle battery when you have to buy a new battery.... Deep cycle bats are designed to be discharged and recharged many times. I ran an Optima Blue top Deep Cycle and love it... never had any problems. Deep cycles generally cost more money.
Hopefully, I have learned my lesson. I got used to those automatic headlights in the Cobalt I was driving before I got my Yaris, and I never had to think about turning headlights on or off.
Tom
Old 08-21-2009, 12:28 PM   #17
YarisOwnersDad
Thanks for all the replies, Peeps.
The car seems to be doing fine, and I guess only time will tell if I did any permanent damage to the battery by leaving those lights on until the battery was flat.
Since I had to drive it home after getting the jump start, I never did put the battery on a trickle charger. I'm sure that would have been the best thing to do, as some of you have suggested.
Tom
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
Slow Cranking - Battery? IGGGY General Yaris / Vitz Discussion 15 08-08-2009 11:50 AM
How long would my battery live with amps while the car is off? eii In Car Entertainment + Electronics (audio / video / alarm) 12 06-15-2009 04:28 PM
