Old 08-22-2009, 09:14 AM   #1
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
Pickup Loss
Ok, I did a search for "loss of pickup" and found nothing. I got a 2007 with 51k on it and the only things that have been done to this animal have been new tires, air filter and oil filter changes.....that's it! Once I accelerate from a stop OR going to pass from changing lanes she doesn't have the "pickup" like she used to from new, naturally. I'm hoping I do not have to bring it to a shop since I like to do my own work. So, simple question that I'm sure has been asked on here before that there is a simple answer to but I cannot find it. I found "pickup", but it was for a guitar and marshall amp on here for sale. Any help would really be appreciated. Thnx.
sambo42xa
oh, three door liftback if that matters.
sambo42xa
sambo42xa is offline   Reply With Quote
Old 08-22-2009, 09:52 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I thought you were missing a truck...
Old 08-22-2009, 12:29 PM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Try Gumout, Regane or Chevron, Techron and clean out the fuel injectors. Tire pressure at 38 psi.
Old 08-22-2009, 12:40 PM   #4
Seafoam Green is also highly recommended to de-gunk an engine...
Old 08-22-2009, 12:40 PM   #5
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Full Tune up, simple as that
Its a Chao!!!
Old 08-22-2009, 01:08 PM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I would be a bit surprised if you already have carbon buildup or fouled up injectors.... but who knows...
i'd check spark plugs, air filter, then do the seafoam, first in the vacuum tube (intake) and then in the gas tank, after that if the problem is still there I'd inspect the timing belt to make sure it's fine.... if there still is no improvement, it might be something stupid like a dirty Mass Airflow Sensor.
Old 08-22-2009, 01:27 PM   #7
RedRide
RedRide's Avatar
I agree that your injectors might need cleaninmg as this is a common problem.
My favorinte injector/fuel sys cleaner is "Seafoam" engine treatment. I add a can to my tank about every 5-6k miles or so and it keeps everything clean. The cheapest place to get it is probably at WalMart.
http://www.seafoamsales.com/
Don't depend on the cleaners already in the gas to keep the injectors clean as the gas companys only put the bare legal minimum in it.
BTW Marshall amps are first rate.
Old 08-22-2009, 01:50 PM   #8
supmet
Drives: 2007 4 Door Yaris
seafoam at 51k? Are you guys smoking crack?
The yaris has no timing belt, its on a chain that is maintenance free.
A "full tune up" on a yaris is also known as "changing the spark plugs" - but one costs 200 and one costs 30 bucks.
How about we check filters, fluids, plugs before we possibly destroy vacuum lines and seize up a brand new engine. For all you guys know he could just be a hypermiler that doesn't realize his ECU is slowing him down because of his driving habits.
Sambo, I promise if you stick around there is lots of worthwhile stuff on this forum, and its not just a big seafoam infomercial. Usually people try to help diagnose things before they blurt out random answers that might help.
Old 08-22-2009, 01:58 PM   #9
auxmike
auxmike's Avatar
Timing belt?
Be careful where you get advice from. The internet is a dangerous place........
Old 08-22-2009, 02:20 PM   #10
RedRide
RedRide's Avatar
Yes! Seafoam at 51k miles. Why not?
If nothing else, make sure your injectors are clean before doing more involved things. Shure filters,etc might need changing,etc. However, that injectors are dirty afrter 51k miles and no cleaner hae been added is just about a given.
Also, Seafaom added to a gas tank will not "destroy" any engine components. Why do youn say this???
Random answers?
Old 08-22-2009, 05:52 PM   #11
sambo42xa
I'll start with the injectors since it was stated, "this is a common problem", which is kind of the answer I was looking for. All Other replies, thank you.
sambo42xa
Old 08-22-2009, 09:25 PM   #12
Yaris Hilton
Smile
I think it's pretty low mileage for an oxygen sensor problem, but they can slowly deteriorate causing reduced fuel mileage and power loss before they fail and set a check engine light.
Old 08-23-2009, 10:16 AM   #13
sambo42xa
I checked out the Seafoam links and I'm not really sure I want to put that stuff in my system.
Is this what some Mechanics use when cleaning Injecter's at the Dealer's/Shop's?
The Regane and Others that you would pour into your tank seems like you would have to do this on a continueing basis Everytime filling up with fuel. Being a dummy over here asking the dumb question's etc., I thought there would be something out there that you just pour into the tank and your good to go for another X amount of more miles (instead of a bottle each time at fill up...unless, by doing this, this cleans the system over a period of time?). Honestly, I think this could be the issue, dirty injecter's. And, as Other have said on here, "it's a start".
sambo42xa
Old 08-23-2009, 10:49 AM   #14
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
If the problem didn't exist BEFORE you did the maintenance, and it does now, then the problem isn't injectors or spark plugs. It's something to do with what you have just done.
TIRES: Did you install bigger tires? If, so, then that's the cause. A taller tire effectively changes your gearing and will reduce acceleration. Either live with it, or install tires that are the same height as stock. Or install shorter tires, which will increase acceleration.
AIR CLEANER: Did you use a stock (Toyota brand) air cleaner? If not, then this could be the cause of the problem. A cheap replacement filter could be restricting the air flow. Or if you used an aftermarket oiled filter, there might be too much oil on it (thus restricting flow).
OTHER STUFF: Examine the engine compartment for loose wires or hoses that you might have disturbed while doing your maintenance.
Reddog99 is offline   Reply With Quote
Old 08-23-2009, 01:16 PM   #15
supmet
That's where I'm at. It probably helps some engines, but I have more miles on my engine then you, and I can guarantee I'm not gunked up yet. Even if there weren't horror stories about it on the internet, I still couldn't recommend sea foaming an engine at 50k miles. There is something else going on if you are noticing power loss. Like others have said, there are a lot of things you need to diagnose or check before you start pouring random cleaners in your more than likely perfectly functioning engine.
Check your air filter, tire pressure, and wires as reddog said. Also check every hose and tube under the hood for cracks and leaks. Check your belts and spark plugs.
But really, you need to give more information before you take anybody's advice. "Loss of power" could be about a million different things.
Old 08-23-2009, 02:32 PM   #16
RedRide
RedRide's Avatar
"A little knowledge is a dangerous thing"
All the so-called "horror stories" aboput Seafoam soley concern putting Seafoam in the oil, sucking it up thorough vacumn lines etc, by people who really do not know what they are doing.
There are absoluly no problems connected to Seafoam when putinng it into the gas tank, only benefits.
It's simple, just pour it into the gas tank. It's fool proof.
Keeping injectors clean should be a part of routine maintenance and whether you use Seafoam or some other sort of qualty injector/ fuels sys cleaner, just do it and stay clear of all the mis information.
The cleaners in gas are totally inadiquate for the long haul and some suplimental cleaner must be added on ocasions.
Old 08-23-2009, 02:34 PM   #17
sambo42xa
Tires and air filter are fine (correct specs). Loss of Power meaning because, your car is in need for a Tune-Up OR dirty Injector's need attention. Apologies on my end. I should have tried to be a little more specific. I took the advice of checking hoses; lines; etc and from what I can see there is nothing that gives any indication to the problem the car is having. Like I said before from reading Other replies on here, sounds more like a tune-up OR dirty Injector/s issue. The car has never been to the Dealer/Shop since day one when I bought it. In the mean time, I MAY try out the Seafoam and use it ONLY in the fuel tank for now before I actually do a tune-up on her, or probably just do the tune-up first.
Again, thnx for ALL the replies and I'll keep you posted.
sambo42xa
Old 08-23-2009, 02:41 PM   #18
RedRide
RedRide's Avatar
BTW, have you guys heard of the "nitrogen enriched" gas from Shell?
This is a bit of a scam.
Most fuels sys cleaners contain a class of chemicles call "amines" among other things
One of the properties of amines is that they have "free" nitrogen atoms.
So, the shell gas is simply nothing different than any other gas and "nitrogen enriched" is just a marketing gimmick
Toyota projects first operating loss since 1941 KCALB SIRAY General Yaris / Vitz Discussion 26 12-23-2008 03:37 PM
