Old 08-25-2009, 05:26 PM   #1
areithan1980
areithan1980's Avatar
Drives: 2007 Yaris Hatchback
AGT Xenon HID H4 issue...
I bought a new kit from a local speed store and they seem to work fine and i know i did all the wirings fine i got the low and high beam working and work s great except for when i turn it on usually on start up it will shake a lil (liquid like movement) or like a loose tunsten movement then it will stabilize after like 10 sec. But after like 40sec to a minunte one fo em will start moving again and its very random sometimes teh right side or left or both then it stabilizes again. I dont know whats wrong ballast or ground. If its a the ground can i hook my grounds directly to my negative battery?? im not sure if i can do this or not but maybe that will give me more or better ground. TY
areithan1980 is offline   Reply With Quote
Old 08-25-2009, 05:46 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
did you use a relay harness?
Old 08-26-2009, 01:34 AM   #3
areithan1980
yes sir!
Old 08-26-2009, 04:38 PM   #4
areithan1980
ok this is weird i removed the shield on the bulb itself since i already got one that came with the factory housinbg but apparently its not good enough shield for HID's so i put back the one that came with the kit and not only it improved my beams but it actualy stop shaking which is weird lol!! i guess i really needed those to be intact lol!! but ty for replies im now a happy HID user lol!
Old 08-26-2009, 04:39 PM   #5
areithan1980
Oh and how do i even adjust the headlights on this car i was ablre to find the adjuster for vertical adjustment how abotu the left and right adjustments? i cant find the screws for it
Old 08-26-2009, 10:36 PM   #6
there is no horizontal adjustement.
Old 08-27-2009, 06:26 PM   #7
areithan1980
ty
xenon hid light bulb lilman717 Cosmetic Modifications (Exterior/Interior) 7 12-19-2008 08:07 PM
KLight HID Conversion Group Buy!! $165.00 shipped!! JRT lighting Sponsors Classifieds Area 4 11-20-2006 10:47 PM
HID Kit XENON Brand Yaris-TJ Cosmetic Modifications (Exterior/Interior) 18 10-27-2006 09:46 AM
