Old 08-27-2009, 03:11 PM   #1
woops
Drives: Jeep Cherokee XJ 1996
Toyota Vitz 1KR-FE engine
Hello guys.. I have a 2005 Vitz with 1KR-FE 1.0 liter engine.. and a question too. :P
I want to know that how is it timed? Does it have timing chain or that serpentine belt does that? If the serpentine belt goes bad, or slips, or breaks, will it be out of time? Well it will be if it doesn't have timing chains.. hence the question
woops is offline   Reply With Quote
Old 08-27-2009, 10:30 PM   #2
2bad4u
Drives: 06 Toyota Vitz RS
http://www.toyodiy.com/parts/q.html
check it here
2bad4u is offline   Reply With Quote
Old 08-28-2009, 08:24 AM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
If you Google "1KR-FE timing chain," the first several hits are the posts you've put on several fora asking this question. A few hits down is this one from Toyota: http://www2.toyota.co.jp/en/tech/env...rtrain/engine/
You'll note the reference to the "chain cover" on the 1KR-FE engine. It has a chain driven valve train, like the other Vitz engines.
Old 08-28-2009, 11:34 AM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
You could just call Toyota and give them your VIN, they can tell you.
Old 06-10-2011, 05:15 AM   #5
Chaminda Jayasinghe
Drives: belta
Is 1KR-FE engine with VVTi ?
Chaminda Jayasinghe is offline   Reply With Quote
1kr-fe, 2005, belt chain, timing
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
Jdm toyota vitz waterproof rear carpet/matt blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 6 01-08-2009 12:25 AM
