Old 08-28-2009, 12:35 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
FS: Dashboard Covers for the '07-'09 LB, ProClip Mounts, 180mm Double Din Trim Piece
FS:
Two Dash-Topper dashboard covers. Both are velour. One is black and the other dark gray.
http://www.dashtopper.com/shop.net/VelourDT.aspx
Both include all pieces they originally came with. The black one will come in its original box and packaging. The dark gray will come wrapped in a plastic bag in a brown box.
Also, on both sets the piece that goes on the driver side glovebox has a hole cut in the middle (I have a Garmin GPS mount permanently attached to my driver side glovebox door and the holes were for the mount to stick through).
$37 + shipping for each set.
ProClip Angled Mount (fits LB only):
ProClip Item #: 853742
http://www.proclipusa.com/?sectionpath=144&pageid=11575
ProClip Center Mount (fits both LB and Sedan):
ProClip Item #: 853835
http://www.proclipusa.com/?sectionpath=144&pageid=11986
$17 + shipping for each ProClip
Finally, I have one 180mm Double Din Trim Piece. I tried modifying it to work with my Pioneer head unit, but it wouldn't fit.
Using a dremel, I shaved down the inner sides of the frame. It has a scratch on both of the bottom corners.
I'm guessing if your good at working with CF or you like wrapping these trim pieces in vinyl or leather, this would be a good piece for you to work on.
$34 + shipping for the 180mm DD Trim Piece
My heatware for references:
http://www.heatware.com/eval.php?id=35947
IsLNdbOi is offline
Group Buy - True Double Din Radio Trim for Liftbacks (180mm opening) CTScott Items for Sale by private party 259 06-08-2011 11:13 PM
FS: Garmin GPS Unit w/ ProClip Mounts, 180mm Double Din Trim Piece IsLNdbOi Items for Sale by private party 2 08-23-2009 02:37 AM
True Double Din Radio Trim for Liftbacks (180mm opening) cruz-gsr Items for Sale by private party 3 07-05-2009 11:02 PM
For Sale True Double Din Radio Trim for Liftbacks (180mm opening) Adriaan Items for Sale by private party 0 05-25-2009 11:16 AM
