Old 08-28-2009, 03:25 PM   #1
ecnal
Drives: 09 Yaris Sedan AT
2009 Yaris 'S'? Where on Toyota.com?
I'm getting a Yaris soon and was playing with the 'build' feature on Toyota.com -- and nowhere on there is there an option to build one with the 'S' trim level - what gives?
Also, can you get a sunroof in a Yaris?
ecnal is offline   Reply With Quote
Old 08-28-2009, 03:27 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
No, you cannot get a Sunroof for the Yaris. As for the S tri, it might not be available in the states.
Old 08-28-2009, 03:39 PM   #3
2+2
Drives: 09 3Dr Manual
Yeah the S isn't officially available in all areas but to make the build feature work try entering a zip code for let's say LA or NY or Chicago and find a place where it is available. Your salesman will tell you and it's probably true that if you want an S he can get it for you.
2+2 is offline   Reply With Quote
Old 08-28-2009, 03:43 PM   #4
ecnal
No, it's avaliable. If you build a yaris on toyota.com and click 'compare' at the first stage, it lists all of them. But they only give you the option for 3door LB, sedan, and 5door LB. I've seen 'S' models on the roads.
Old 08-28-2009, 03:55 PM   #5
ecnal
echo, i found it. using the same zip. thanks!
Old 08-31-2009, 12:55 PM   #6
b_hickman11
Drives: 08 Sedan
Hopefully you can still find an 09 because I heard they were doing away with the "S" in 2010.
Old 08-31-2009, 03:39 PM   #7
I had a moon roof installed in my 09. Attention to Detail in Middletown, CT (www.atd1.com) installed mine. They do sunroof and moon roof installations for many CT and MA car dealers.
whaty kind of keys does a new 2009 yaris yrs come with PAULY Australia 8 09-12-2009 03:55 AM
No CarSeat Covers for my 2009 Yaris Liftback!!!!! HELLLPPPP PLEASE! paguy General Yaris / Vitz Discussion 1 06-12-2009 01:33 AM
Retro fit Cruise Control into a 2009 Yaris hatchback 42ezra Performance Modifications 1 05-02-2009 11:04 PM
