Old 08-29-2009, 06:33 PM   #1
mario98c
mario98c's Avatar
Exclamation how to remove thw windows handle???
i need to remove the door panels of my yaris sedan 09 but i don't have power windows so i need to remove thw windows handles!!! How i do that???
Old 08-29-2009, 06:40 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
if the yaris is like ... well every other car out there... there will be a tiny C shaped clip that will hold the window crank in lace. Take a thin piece of cloth and slide it in between the crank handle and the door panel.... work the cloth in and you should pop off the clip.... You might have to rotate the cloth around a bit... never know which way the clip is facing.
taking the clip off is the easy part... putting it back on is the hard part.... at least that was the case with my 97mazda.
If you plan on doing this more than once... you might want to go to an auto parts store and just pick up a window crank remover tool...just a thin piece of metal or plastic that pushes the clip out.
Old 08-29-2009, 07:14 PM   #3
mario98c
mario98c's Avatar
i can't get the clip out!!! i push the door panel to try to see the clip but i can't!! In the rear doors i push the door panel and i see the clip but in the front door i can't.
Old 08-29-2009, 11:19 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
grab two butter knifes and try it again... or watch some of these videos for an idea...
http://www.youtube.com/watch?v=7YyktubQKwc
you tube is your friend
Old 08-29-2009, 11:33 PM   #5
mario98c
mario98c's Avatar
Thanks!!! That videos help me a lot!!!
Old 04-02-2014, 10:18 PM   #6
fuuao
Drives: 2008 yaris sedan 4 door
I need to remove the door panels of my yaris sedan 08 the power window switch is rattling.
fuuao is offline   Reply With Quote
DIY : How to remove door panels FEINT DIY / Maintenance / Service 13 11-18-2021 02:16 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
E-brake handle stevencyt Cosmetic Modifications (Exterior/Interior) 2 05-11-2007 03:18 PM
[DIY] To remove logotipos of the mark Sérgio Barros DIY / Maintenance / Service 6 02-23-2007 07:32 PM
