Old 09-04-2009, 01:29 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
Exhaust Tip Sizes. Which one will fit?
Which one of these exhuast tips will fit my '09 5-door LB? Each tip comes in two sizes. Not sure which one will fit.
http://www.autoanything.com/exhausts...A2440A0A0.aspx
Outlet Size 3 5/8 x 2 1/2", Inlet Size 2.25", Length 4"
or
Outlet Size 4 1/4 x 3 1/2", Inlet Size 2.5", Length 5"
http://www.autoanything.com/exhausts...A2445A0A0.aspx
Outlet Size 3 x 4 3/4", Inlet Size 2.25", Length 4.75"
or
Outlet Size 4 x 4", Inlet Size 2.5", Length 6"
Old 09-04-2009, 02:06 AM   #2
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
Red Horse is offline   Reply With Quote
Old 09-04-2009, 02:38 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
Thanks for the picture, but that doesn't answer the question...
Old 09-04-2009, 02:45 AM   #4
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
measure the damn thing
Bob Dog is offline   Reply With Quote
Old 09-04-2009, 02:48 AM   #5
IsLNdbOi
IsLNdbOi's Avatar
I would, but I have an old exhaust tip in there right now and don't have the time to remove it to measure. Also, I'm not sure what outlet size and inlet size are.
If you have a problem with me asking, why even post in this damn thread?
Old 09-04-2009, 03:05 AM   #6
Ryu
I think the one with length 6" might stick out a bit, I would suggest just buy all other 3 with different size and try to fit them yourself, keep the one you like and return the rest.
Old 09-04-2009, 03:09 AM   #7
IsLNdbOi
IsLNdbOi's Avatar
Yeah, I don't really want a long exhaust tip either. I'm hoping the 4" one fits properly, but I'm looking for someone to confirm.
Old 09-04-2009, 05:58 AM   #8
alvant
Drives: 07 Yaris 1.5 E
Diameter of the stock exhaust outlet is 50mm, about 1.96"... hope this helps...
alvant is offline   Reply With Quote
Old 09-04-2009, 06:39 AM   #9
kimona
kimona's Avatar
Drives: 2014 White VITZ
This one fits the HB perfectly. The measurements are found in the link. You can find the same one at Walmart for about $12.
http://www.jcwhitney.com/autoparts/I...D:100000186093
Old 09-04-2009, 10:44 AM   #10
IsLNdbOi
IsLNdbOi's Avatar
Thanks alvant. That's much smaller than the 2.25" inlet of the one I want. I hope the clamp can adjust to that size.
Thanks kimona. That's quite a bit longer than what I want though. It's 8" long vs. 4" for the one I linked to above.
Old 09-04-2009, 01:51 PM   #11
kimona
kimona's Avatar
This one at 8" fits perfectly. Push it all the way back onto the exhaust pipe until it's flush against the plate, then center and tighten. It fits under the bumper quite a bit.
Old 09-04-2009, 08:06 PM   #12
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
You don't have to attach it at the very end of the exhaust. Both tips you posted will probably fit but my touch the bumper.
Old 09-04-2009, 08:11 PM   #13
PHXDEMON
PHXDEMON's Avatar
Also that tip kimona posted can be picked up at walmart for like 12 bucks and is pretty decent quality. It's no borla tip but pretty good for the price.
Old 09-04-2009, 08:37 PM   #14
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
I gots me a Walmart tip!
RUFFSTUFF is offline   Reply With Quote
Old 09-04-2009, 09:00 PM   #15
IsLNdbOi
IsLNdbOi's Avatar
I have the square version of that tip from Wal-Mart. I got mine from Pep-Boys. It's shorter than the one from Wal-Mart, but it still makes the exhaust pipe look too long.
I'm going to try the Borla to see if I like it any better.
Old 09-04-2009, 09:20 PM   #16
kimona
kimona's Avatar
I'm not sure I understand. With the 8" long tip, it fits under the bumper edge a full 2".
Like PHXDEMON explains above, "You don't have to attach it at the very end of the exhaust." Push the tip back all the way until it fits snugly up against the exhaust pipe plate. Geez, a 10" long tip would be flush with the bumper edge.
Old 09-04-2009, 11:32 PM   #17
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
sorry im tired...been working for the last 16 hours....!!!
the_boss is offline   Reply With Quote
Old 09-08-2009, 11:19 AM   #18
charleschia1986
charleschia1986's Avatar
Drives: Yaris RUSH HatchBack
from the attached picture.
i am pretty sure the middle one will FIT because that's exactly what i am using now...
regards, hope this helps..
charleschia1986 is offline   Reply With Quote
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
exhaust tip DJ_stone Cosmetic Modifications (Exterior/Interior) 1 01-20-2009 07:52 PM
Exhaust Tip Decision ruimond Performance Modifications 19 12-15-2008 12:49 AM
What aftermarket exhaust will fit the Yaris Sedan? dngz Performance Modifications 2 10-02-2006 01:41 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
