Old 09-05-2009, 11:29 AM   #1
dj_corrosive
Drives: 2008 Black Sand Pearl Sedan
Help w/install of iPod adapter+HD Radio Tuner
Hey guys, first of all I want to say what a great site this is....it's helped me find and install all sorts of crazy things for my car...Thanks!
I have a Pioneer AVIC-Z1 HU and I wanted to add iPod & HD radio capability so I bought the CD-IB100II iPod interface adapter and the GEX-P10HD HDRadio tuner. My problem is I am at a loss on how to power the two units. They both have their own power wire and ground, plus they each have an inline fuse. Where can I tap into a constant 12v source, and will I need a seperate source for each unit?
I'll be installing these units side by side under the passenger seat if that helps any. I'm pretty good at most DIY projects, but power wire always scares me a bit...I want to make sure everything is safe and done right. I don't know if I can tap into the HU's wiring harness or how I would do that if it is possible, or if I need to look elsewhere. I'd appreciate any help from you guys. Thanks!
dj_corrosive is offline   Reply With Quote
Old 09-05-2009, 09:45 PM   #2
I would tap the supply to the HU. Both of those modules draw minimal current compared with the HU.
Old 09-06-2009, 07:20 AM   #3
dj_corrosive
Thanks for the reply....so would it matter where on the power supply I tapped into it (i.e. before or after the harness)?
Old 09-06-2009, 08:40 AM   #4
No. Either side is fine. At both points you're already downstream of the fuse.
Old 09-06-2009, 09:22 AM   #5
dj_corrosive
OK...one last question...I'm going to use POSI-taps to tap into the wire, do I need to do a sperate tap for each unit or can I combine both the iPod adapter and HD radio tuners power wire into one connection point (i.e. one connector for both units)?
Thanks again!!!
Old 09-06-2009, 09:30 AM   #6
On tap would be fine for both.
Old 09-06-2009, 09:55 AM   #7
dj_corrosive
Awesome...thanks, I'm off to start the install!
DIY: Installing XM Radio with SureConnect antenna adapter The Marshall DIY / Maintenance / Service 0 07-11-2009 09:57 AM
FT: Pioneer AVH-4900DVD With iPod Connection (CD-IB100II) FreddysEvolutionIX Items for Sale by private party 4 01-29-2009 11:02 PM
is iPod possible in European type 1 radio? heistp In Car Entertainment + Electronics (audio / video / alarm) 4 05-01-2007 11:35 AM
