Old 09-07-2009, 12:15 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Which is more wise
If I were have to run a 400km straight road, in terms of fuel efficiency. Which one would be better? No a/c, drag or whatever other factors involved.
Yaris going at
160kph/100mph = 2.5Hrs
Or
80kph/50mph = 5Hrs
The rule is to save as much fuel as possible.
Cheers
caineroad is offline   Reply With Quote
Old 09-07-2009, 12:20 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
80
Old 09-07-2009, 12:21 PM   #3
160kph for 2.5 hrs = road side suspension
What are you getting at here?
Old 09-07-2009, 12:22 PM   #4
caineroad
caineroad's Avatar
Despite the road limit. 80?
Old 09-07-2009, 12:23 PM   #5
Brentorius
Drives: 07 Mazda MX5 Copper Red
80kph/50mph = 5Hrs
If you are trying to use as little fuel possible, stick with the speed that nets you more mpg.
Brentorius is offline   Reply With Quote
Old 09-07-2009, 12:25 PM   #6
caineroad
caineroad's Avatar
Originally Posted by Brentorius View Post
80kph/50mph = 5Hrs
What's the speed I get the most mpg?
Old 09-07-2009, 12:26 PM   #7
supmet
Drives: 2007 4 Door Yaris
45 mph
Old 09-07-2009, 12:28 PM   #8
caineroad
caineroad's Avatar
45mph = approx 70kph
Thanks
Old 09-07-2009, 08:40 PM   #9
BailOut
Steals terrorist's lunch
BailOut's Avatar
Somewhere between 35 and 45 MPH, depending on the road and weather conditions, and any elevation changes.
- Brian
Share the Road
Old 09-08-2009, 02:02 AM   #10
ddongbap
You forget wind resistance. Higher the speed, the more it sucks.
Old 09-08-2009, 12:52 PM   #11
60kmh in 5th gear is the best fuel saver. But you have no choice but to go faster at the slightest incline.
Old 09-08-2009, 12:56 PM   #12
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
It's quite impossible to exclude drag, or "whatever other factors [are] involved."
The correct answer has been given several times already.
