Old 09-10-2009, 10:47 PM   #1
bribri
Drives: white stock yris
brakes
I'm getting brake fade at the track. I'm using oem disc and pads.Where can I find pads which will tollerate higher heat. I don't mind switching pads for track use but I can't cant find track specific pads for a 2007 yaris. Any help would be appreciated>
Brian
bribri is offline   Reply With Quote
Old 09-10-2009, 10:48 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
http://shop.microimageonline.com/cat...c?categoryId=3
Old 09-10-2009, 10:59 PM   #3
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Or put in cooling ducts
Old 09-10-2009, 11:02 PM   #4
AlexNet0
AlexNet0's Avatar
that too, look up the DIY on brake ducting. lol
Old 09-11-2009, 12:26 AM   #5
and fluid, and lines. If you're cooking your fluid you'll get fade that way too.
Old 09-11-2009, 01:46 AM   #6
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
All of that, and, of course... better tires, suspension setup and skills so that you can corner faster and BRAKE LESS.
Old 09-11-2009, 10:01 PM   #7
bribri
what is the difference betwen dot 3,dot 4 an dot 5 brake fluid?
Old 09-11-2009, 10:16 PM   #8
Loren
What?
Loren's Avatar
Google is your friend.
Mainly, the difference is in the temperature spec. Dot 5 is silicone based and has some other benefits (and some potential pitfalls depending on what you want to use it in).
For racing, get a good high-temp DOT 3/4 like Motul or ATE. Pay close attention to the actual brake fluid spec, not just the DOT spec. The DOT spec is just a minimum that must be met, so you can have "streetable" DOT 3 that isn't nearly as temperature tolerant as "race" DOT 3.
Old 09-14-2009, 09:48 AM   #9
bribri
after a bit of research I've decided to change the brake fluid, clean and lubethe front brake and bleed bleed bleed.I'll wait for the roter to wear before i change pads.
Old 09-14-2009, 12:06 PM   #10
AMSOIL is another good DOT4 brake fluid.
www.trulube.com (lazerdot is the dealer, he's a member on here)
Old 09-14-2009, 01:01 PM   #11
markitect
if the pedal is still firm, and it is just not braking as hard as it should, then you don't need fluid or lines, just pads.
If your pedal suddenly gets soft then go for the fluid.
markitect is offline   Reply With Quote
Old 09-14-2009, 03:07 PM   #12
Loren
What?
Loren's Avatar
There's no question that you need pads. The stock pads were never intended for track use and will fade VERY quickly. You need good higher-temp pads, and fluid that will hold up to the higher temp the pads will operate at.
Ducting helps A LOT, too.
Old 09-14-2009, 04:03 PM   #13
JCS_IMPORT_25
Drives: red vitz
do any of you know where i can get a brake drum to disk conversion
JCS_IMPORT_25 is offline   Reply With Quote
Old 09-14-2009, 06:49 PM   #14
http://shop.microimageonline.com/pro...7&categoryId=3
Old 09-14-2009, 08:07 PM   #15
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
We need a predictive text-like feature that will just automatically forward users to www.microimageonline.com whenever they type "where can you find..."
Old 09-14-2009, 08:09 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
brake fade at the track? wow
Old 09-14-2009, 08:39 PM   #17
LOL, nah there's other product sources too! "I don't sell brake fluid" -- so there.
Old 09-14-2009, 10:45 PM   #18
ozmdd
ozmdd's Avatar
I'll bet you would if there was a JDM variety...
A few questions about suspension, tires, and brakes. supmet Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-02-2009 04:55 PM
Weird question about my brakes brainless twit General Yaris / Vitz Discussion 8 01-22-2009 10:59 AM
Brakes Geelmeel General Yaris / Vitz Discussion 16 06-29-2007 07:58 PM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 05:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
