Old 09-10-2009, 08:00 PM   #1
Slick
Slick's Avatar
Drives: '09 3-Dr
DIY amp wire running and radio trim removal
Hey everyone, this is my version of the end all amp wire install. It also covers how to dismantle the non-integrated stereo trim. Any and all feedback is welcome.
Amp wiring DIY.pdf
Old 09-10-2009, 08:57 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
cool... good job.
Old 09-11-2009, 11:37 AM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Very nicely done! This should be added to a new edition of the DIY compilation PDF.
Stickied.
Old 09-14-2009, 01:04 AM   #4
Revsson
I read through the pdf rather fast, but where did you ground the amp in the back?
Old 09-14-2009, 11:48 AM   #5
Slick
Slick's Avatar
Drives: '09 3-Dr
I'll never tell haha. Mostly because my method of grounding could be considered questionable. And since the DIY was about running the wires, I didn't want any "sticklers about grounding" questioning my connection. So I left it out for a reason. I don't recommend my way of grounding to someone that is unfamiliar with making solid ground connections.
Old 01-15-2010, 01:01 PM   #6
brutal910
brutal910's Avatar
Drives: 2007 tyota yaris 2 door hatchb
hey thanks for the diy. that was a good hands on demo. just bought a 2007 3 door yaris.thanks again.
brutal910 is offline   Reply With Quote
Old 01-15-2010, 04:09 PM   #7
MiniPearl
Drives: 2009 Polar White sedan
Hi everyone. I am a new 09 Yaris sedan owner and wish to put in an amp with my factory head unit so everything looks stock. I have a 4 channel 680 watt amp, a line output converter and an amp wiring kit but am new to the install game.
i think everything would be relatively easy, Im just at odds with putting in the converter and the remote wire. Is it that difficult to diy.
MiniPearl is offline   Reply With Quote
Old 01-21-2010, 08:49 AM   #8
MiniPearl
I figured everything out. The only real problem was matching the head unit's wires to the Line out converter wires other than that everything was simple. The remote wire went into the harness with the ignition wire and connected to the amp. I do however suggest one starts early in the morning because it may take some time to remove the paneling. Amp + Line Out converter + Amp wiring kit = medium difficulty/very possible.
Old 03-14-2010, 06:25 AM   #9
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
ok... so where would be a good place to ground your amp?
Old 03-16-2010, 08:16 PM   #10
typicaljawaiian808
Drives: '09 Yaris Sedan
i got that same deck
Pioneer
Ascendant Audio
Sundown Audio
DC Power Engineering
Knukoncepts
Fosgate
Stinger
typicaljawaiian808 is offline   Reply With Quote
Old 04-01-2010, 08:32 PM   #11
captaincrunch
Chris
captaincrunch's Avatar
Where did you tie your amp remote wire into. I'm not seeing a blue w/ white stripe wire that I'm used to. I tried connecting it to the accessory...failed. Would the power antenna work?
captaincrunch is offline   Reply With Quote
Old 04-02-2010, 08:51 AM   #12
Palmer812
Drives: 2010 Meteorite Metallic LB
What brand of radio do you have?
Palmer812 is offline   Reply With Quote
Old 04-02-2010, 10:26 PM   #13
Slick
Slick's Avatar
Drives: '09 3-Dr
@captain- the wiring harness that came with the radio had an amp remote wire on it. It even had a blue tag on it. So I took it for granted and wired it to that without actually paying attention to the color.
@palmer- my radio model number is listed in the interior section of my garage to the left.
Old 04-03-2010, 06:46 PM   #14
swidd
Drives: Yaris HB
I just put a Clarion NX 700 in my Yaris, and I tried grounding the parking brake wire. When I have the unit turned on, and touch ground with the parking brake wire (using the factory harness ground), the 'Audio Only' message disappears and I can play video. However when I leave it connected to ground and turn the unit on again, it says 'Audio Only'.
Anybody know a solution? It seems the unit is outsmarting me. Help me outsmart it! ~ before the machines take over!
Old 04-03-2010, 07:07 PM   #15
Palmer812
You need to use a toggle switch and hook one side of it to ground and the other side to the parking brake wire on the Clarion. When you turn the unit on and the audio only is displayed you turn the switch off then back on and it will work.
Old 04-03-2010, 07:44 PM   #16
captaincrunch
Chris
Well, I don't think I cleaned the ground good enough. My dvd player was a gift and was purchased online. I'll just look at the wire harness, because the wire didn't exactly match color for color.
Old 04-03-2010, 08:55 PM   #17
swidd
Drives: Yaris HB
Thanks Palmer. That worked. $1.99 to radioshack for the switch, soldered it. Actually didn't attach it to the parking brake, just made a very improvised ground, connected that to the switch, and, like you said, I have to toggle the switch on and off to put it on video-and-nav mode. Thanks!
Old 07-04-2010, 10:34 PM   #18
Revsson
Slick,
I used part of your DIY for installing power wires into my car. I forgot about removing
the plastic piece above the battery, as that would have been very convenient. I also
did not cut the carpet, but removed some bracket up to the top right, so I could pull
the carpet back to route the wires. However, in my impatience, I ended up tearing
the carpet or insulation , but at least it is not where it can be seen.
I had a heck of a time getting both power and ground wires under the trim
piece around the rear seatbelt. I have the sliding rear seats, so did not
want any wires exposed back there.
I bought a grommet from Napa, but can't find the exact model number.
I think it was for a 3/4" hole. We had a hard time getting that on the
firewall, but ended up lowering the computer to get our hands in there.
So, now I have power and ground cables in the rear by the spare tire, for
future radio amp installation.
DIY amp wire running and radio trim removal Slick DIY / Maintenance / Service 0 09-10-2009 08:00 PM
