Old 09-13-2009, 04:39 AM   #1
regal
TRD Springs & rattling
I installed TRD springs with the Tokiko (sp?) Blue shocks. Also Scion rims with 195/55/15 tires.
On a road with an uneven slightly bumpy surface sometimes I hear a rattle at the top of the front shock towers.
I didn't cut my bump stops, could that be the issue? This seems different as it is occuring when the springs aren't highly compressed (like from a large bump in the road.)
Should I tighten the nut at the top of the shock?
Old 09-13-2009, 04:51 AM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
maybe you have something rattling in the little compartment under the cover.
Check out my Build thread:
Old 09-13-2009, 04:57 AM   #3
regal
Good thought I'll check.
Old 09-14-2009, 04:55 AM   #4
ezhacker1
ezhacker1's Avatar
oops i was thinking about the rear there. either way check for something trapped
Old 09-14-2009, 07:34 AM   #5
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
WELL, if that had happened in your civic what would you check? maybe that metal wiper cover thing you had to remove to do the job is loose.....
Old 09-14-2009, 04:31 PM   #6
kngrsll
Apexing Egg!!
kngrsll's Avatar
this issue has plagued me at the track. it has happened twice now near the end of the day. sounds like the same thing, a loud clunk develops. i have yet to figure out what causes it. what we have done is pull the entire strut and spring off, re-torque everything, and put it back together (in 40 mins to get the car back on track lol). so far, it has worked 2 out of 4 times. nothing seems loose when we do it, but it goes away, and stays away.
i still have no idea what causes it, but to fix it, we just retorqued every bolt on the front suspension.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 09-15-2009, 11:24 AM   #7
MUSKOKA800
MUSKOKA800's Avatar
Over 30,000 kilometers on my TRD suspension and not a noise to be heard.
Do the bump stops need to be trimmed with TRD springs? schleppy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 07-10-2009 07:45 PM
TRD Springs Vs Tanabe DF210...The Title Bout detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 47 05-23-2009 10:02 PM
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 09:54 AM
TRD shocks with tein or trd springs? UKblackyari Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-20-2008 12:20 AM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
