Old 09-15-2009, 08:32 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Worn out tires - help
I have a set of near worn out tires at the front L and R. And the rear L and R are almost new. When I turn in a curve at speed, sometimes I can hear squeaking noise. So I did a rotation today, now the new set are at the front and the near worn out set are at the rear.
Is there a problem with that? The car is heavier at the front and is FWD, would a rear skid more likely to happen in terms of the wheel set I have now?
Cheers
caineroad is offline   Reply With Quote
Old 09-15-2009, 09:29 PM   #2
supmet
Drives: 2007 4 Door Yaris
You'll be ok(definitely not good, but ok) as long as you don't drive in the rain. I hydroplaned and spun out into a guard rail on the freeway with good front tires and bad rear tires. It was a similar weight FWD corolla that this happened in btw.
Rotate sooner next time. A lot sooner
Old 09-15-2009, 10:19 PM   #3
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I buy two tires at a time, when the fronts wear out, I move them to the back and put two new ones on the front, i never move worn out tires to the rear.
I know, im not following the rotation pattern.
Old 09-16-2009, 09:18 AM   #4
markitect
i would get 2 new tires, you should be able to get matching ones pretty cheap, and it's always easier when your paying for 2 tires at a time instead of 4.
markitect is offline   Reply With Quote
Old 09-16-2009, 12:24 PM   #5
caineroad
caineroad's Avatar
Oh... Ok thanks for everyone's input. I'll try not to drive in wet condition :)
Old 09-17-2009, 12:19 AM   #6
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
That's what I did but mine were worn due to the previous owner dropping it without getting an alignment.
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
NEED USED TIRES!!! natethegreat38 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 12-06-2008 12:11 AM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
