Old 09-19-2009, 10:02 PM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Help with header install - I'm stuck
Everything was going great, I got the stock header out, had disconnected the O2 sensor, moved the donut from the stock header to the new one and started to remove the O2 sensor from the old header. It was very difficult, so I went and bought a longer wrench, so I can apply more force. After a few revolutions, just enough to see the washers inbetween moving, it got stuck. I've been trying really hard to get it moving again, but no luck. I sprayed a little W40 at the base of the bolt, but so far it hasn't helped...
Any advice? Should I try a bigger wrench? I'm slowly starting to ruin the nut with all the force. What should I do?
Old 09-19-2009, 10:10 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
tighten it
then loosen it
tighten it again
then loosen again
its a trick ive used with boogered hard to come out spark plugs it may work with o2 sensor
Old 09-19-2009, 10:39 PM   #3
Brian
Brian's Avatar
It also helps to use an O2 sensor socket
Old 09-19-2009, 10:40 PM   #4
fmicle
fmicle's Avatar
Yeah, I was wondering if I can get the O2 sensor from a Toyota dealer if I ruin it. Does anyone have an idea how much the part costs?
And also, can I drive the car without the O2 sensor in place? Until I get a replacement?
Old 09-19-2009, 10:46 PM   #5
Brian
Brian's Avatar
You can order a new one but they're over $100 I think. I wouldn't recommend drivng without one.
Old 09-20-2009, 12:32 AM   #6
supmet
Drives: 2007 4 Door Yaris
Originally Posted by hatchbackkid82 View Post
Just bought a brand new primary O2 sensor that cost me $171, the original one broke when I was installing my header.
http://www.yarisworld.com/forums/sho...d.php?p=388327
i lol'd
Old 09-20-2009, 01:47 AM   #7
fmicle
fmicle's Avatar
Alright, I'm done, it was a bitch, to say the least
I took my bike rack apart so I could use the main bar/pipe as an extension to my wrench. Then I slowly loosened the O2 sensor until it came off. I noticed that the thread on the bolt is 75% ruined, but I was able to mount it on the new header just fine.
Another disappointment came when I realized I wasn't going to be able to attach the header to the engine bracket. No matter what I tried, the holes just wouldn't align. So I used a smaller diameter bolt and nut to fasten it, instead of the original thicker bolt that threads into the header collar. I hope it's strong enough.
Then I took it for a ride and everything feels alright
Did anyone experience similar issues with the fitment?
Old 09-20-2009, 02:09 AM   #8
Brian
Brian's Avatar
Mine fit perfectly.
Old 09-24-2009, 01:56 AM   #9
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
What header did you buy? Was it a DC Sports?
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 09-24-2009, 02:05 AM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
why not a box end wrench? you're taking the manifold out of the car anyway, just unclip it from the harness and do this on the ground?
Old 09-24-2009, 08:53 PM   #11
bronsin
bronsin's Avatar
Next time heat the header with a torch near the sensor...
Old 09-29-2009, 02:46 PM   #12
hatchbackkid82
Drives: .
mine broke too i had to pay 180 for a new one, my header lined up perfectly, car feels great now
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
