Old 09-20-2009, 05:00 PM   #1
E.R.G
E.R.G's Avatar
Drives: Yaris Sedan
2NZFE-1NZFE
Halo yaris world members. I have a 2001 yaris HB with a 2NZFE engine. I want to know if i put a 1NZFE in my car what should i do. Do i have to change the wiring harness and the Ecu? I would like to get some answers pls. Thanks
E.R.G is offline   Reply With Quote
Old 09-20-2009, 07:35 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
most likely you would need the complete 1nz harness and ecu, but I would ask CTScott, he is more knowledgeable in the wiring and management aspects.
Old 10-26-2009, 01:25 PM   #3
mohamedmohsen2000
Drives: Toyota Corolla 2002
I asked some technicians in Egypt, working on Toyota cars, they told me that you just need to swap the engine and nomore. The ECU is the same, the wiring is the same.
He convinced me when he showed me the details of each car. 2NZ-FE and 1NZ-FE have the same ECU, same fuel pump, same Dashboard, and even the same transmission.
But i still need to be sure from yarisworld experts :)
My car is the big sister of the yaris, which is the Corolla 2002 :)
mohamedmohsen2000 is offline   Reply With Quote
Old 10-26-2009, 04:17 PM   #4
I noticed in the European service manual that the 1NZ and 2NZ use the same ECM. I wouldn't doubt that it's plug and play.
Old 10-31-2009, 06:31 PM   #5
mohamedmohsen2000
If it is plug and play as you think, then the difference in performance is not that large.
do you know the Torque in N.m and Horsepower of the 1NZ-FE ?
According to wikipedia, the 2NZ-FE is 85 HP and 121 N.m
and the 1NZ-FE is 110 HP and 140 N.m
The difference can't be neglected i think. Will the 2NZ-FE transmission survive the 1NZ ?
Old 11-14-2012, 05:06 AM   #6
speed1
Drives: vitz rs
Hi guys, who know 4 sure if 1nz e 2nz use same
transaxle same gears same final?
1st 3.545, 2nd 1.904?
Same housing?
Final 4.3?
speed1 is offline   Reply With Quote
Just wanted to share this: turbo 1NZFE as400g33k Performance Modifications 34 04-26-2013 10:39 AM
1NZFE VS 4EFTE Parmas Performance Modifications 5 11-14-2009 11:34 AM
OIL PRESSURE in 1NZFE Engine Giupo Forced Induction Forum 2 09-03-2009 10:08 PM
1NZFE K1 by Carrillo Rod interest list xBoosted Forced Induction Forum 20 01-20-2009 02:51 PM
