Old 09-22-2009, 02:16 AM   #1
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
need wheel info on a non toyota wheel.
so i found this guy who is selling a set of these for cheap
they are 15x6 ET43 but i dont know if the measurement of the center bore is going to give me problems. i have been searching for hours for some specs in this wheel. http://www.flickr.com/photos/jba1rylie/2120629139/
thanks anyone who helps
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 09-22-2009, 02:43 AM   #2
Brentorius
Drives: 07 Mazda MX5 Copper Red
Looks like kia oem cb is 56.1mm
http://www.gpiperformance.com/produc...ucts_id=102194
Shouldnt be a problem since ours is 54.1mm
Brent
Former Yaris Owner
Brentorius is offline   Reply With Quote
Old 09-22-2009, 05:12 AM   #3
Cosmonaut
The Last Baron
Cosmonaut's Avatar
dammit dude. it proly took you a few minutes to find that. gotta know where to look i guess.
Much thanks for the info.
hopefully if the guy still has them AND my "financial adviser" says yes i will be rollin on new wheels. WOOT!
| UR 19mm sway |
Old 09-22-2009, 08:33 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
i'm not sure all spectras had 4X100 bolt pattern. can you find out what year?
Old 09-22-2009, 08:45 AM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Hmmm... Tamago brings up a critical point. I seem to recall the Spectra has 4 x 114.3 bolt pattern, but perhaps the 2004 has 4 x100. Anyway, check it out to be sure.
EDIT: Search indicates 2004 Spectra bolt pattern is 114.3
Old 09-22-2009, 10:38 AM   #6
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
FYI - many people are finding this info quickly by going to a website like tirerack.com and entering the vehicle info, then searching for custom wheels. It will tell you what size/pattern is appropriate.
Old 09-22-2009, 01:09 PM   #7
Here's a site with a chart of Kia models. It looks like just the Optima used 4x114.3. The rest of the 4 bolt ones are all 4x100.
http://www.discountedwheelwarehouse...._Reference.cfm
Old 09-22-2009, 05:02 PM   #8
Cosmonaut
The Last Baron
Cosmonaut's Avatar
thanks for the input everyone. i went by this sites info.http://www.hubcaphaven.com/mm5/merch...egory_Code=855 and the wheel says 4x100. at tirerack it says the 2004 spectra models gs ,gsx, ls, and lx use 4x100 EXCEPT the ex model that tirerack says 4x114. DAMN this is more complicated than i thought. if the guy would return my call it would be so easy.
thanks again everyone.
| UR 19mm sway |
Old 09-22-2009, 06:03 PM   #9
sex
sex's Avatar
Drives: 09 5DR
If you cross reference car-part.com, the alloys for the 2004 are the same for 2005 and 2006. In those years the bolt pattern is 144.3. Kia alloys from 02/03 were 4x100 but they're 14"
Help me identify this stock toyota wheel martenswd Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 04-25-2009 12:08 AM
Two Millionth Toyota Sold in UK VitzBoy General Yaris / Vitz Discussion 0 03-06-2006 03:52 PM
