Old 09-25-2009, 01:18 PM   #1
charleschia1986
charleschia1986's Avatar
Drives: Yaris RUSH HatchBack
original factory front speaker
Hi there,
may i know how many inches is our Yaris Hatchback 2008 front speaker?
because i am thinking of getting a split that fit the original size, any good and cheap splits that u guys can think of? # i have 2 spare channel from my current amplifier which has 40rms watts X 2.
thanks.
charleschia1986 is offline   Reply With Quote
Old 09-25-2009, 01:32 PM   #2
splits?
oem front speakers are 5.25" but you are better off fitting 6.5" without any modifications.
Old 09-25-2009, 02:39 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
6.5" up front.
See this thread: http://www.yarisworld.com/forums/showthread.php?t=1523
Old 09-25-2009, 03:38 PM   #4
ryota
Dry Bones
ryota's Avatar
Drives: 2008 Yaris Liftback
Send a message via AIM to ryota
agreed with the 6.5. it seems like they should have been in there to begin with
Ryota
ryota is offline   Reply With Quote
Old 09-25-2009, 04:27 PM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
he's probably talking component speakers when he says "splits" he's from pert, which makes him an aussie. Gotta keep in mind the vernacluar people round the world might use.
If running components, If you want the tweet hidden in the stock location 5.25's could probably allow for your tweet and mid to be mounted and hidden without any problems. HOWEVER, the 6.5" with the tweet mounted in a visable place SHOULD (key word) give you better sound.... it all depends on how they are installed and which way that point.
5.25's can't play much below 100hz... or sometimes 120hz. 6.5's often times can play down to 80hz without problems. If you don't have subs, and want the slightest bit of bass you'll want the 6.5's.
FREE ORIGINAL FRONT SPEAKER(S) + REAR SPEAKER click.mine In Car Entertainment + Electronics (audio / video / alarm) 3 11-01-2014 01:55 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
