Old 09-28-2009, 11:47 PM   #1
Vitz RangaaaH
Vitz RangaaaH's Avatar
Arrow ghetto riged rear speakers to amp directly
and now I hear whiring (the car) through the speakers. What are some things to do or
Check for?
Vitz RangaaaH is offline   Reply With Quote
Old 09-29-2009, 12:16 AM   #2
goku87
goku87's Avatar
Drives: Black HB
define "whiring." as in, when you rev the engine, you here a tone directly proportional to the rpm's of the engine?
Old 09-29-2009, 06:13 AM   #3
Vitz RangaaaH
Yes that's exactly it.
Old 09-29-2009, 08:29 AM   #4
Yaris - GP
Drives: 2007 Yaris Sedan
Sounds like there isn't sufficient suppression on the power lines to either the hu, amp or both, or the line in cables to the amp are running too close to a main electrical line in the car.
First check the path that your power and line cables follow. If they are clear from the cars electricals then install a suppressor (not sure of the technical term) directly on the power line to the hu. Shouldn't really have to put one on the amp power, but the problem could also be a faulty amp.
Yaris - GP is offline   Reply With Quote
Old 09-29-2009, 01:26 PM   #5
supmet
Drives: 2007 4 Door Yaris
Did you ground the amp and make sure you are actually hitting metal?
Old 09-29-2009, 04:43 PM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
99.9% of the time your issue is caused by a connection with high resistance AKA (A BAD GROUND or Power connection).
There are many reasons for this. Ground cable connected to painted metal or metal that barely touches the chasis, using a self tapping screw that doesn't hold tightly to secure your ground cable. Using too small of power wire.
that .1% = a bad amp.
Old 09-29-2009, 08:07 PM   #7
Lafiro
Drives: 06 Yaris Sedan
I had this problem once, and solved it by turning down the gain on everything(amp wise). Now its quiet/the way it should have been.
Old 09-30-2009, 02:56 PM   #8
Vitz RangaaaH
I've taken all of your advice, and now it works no problem. Thanks for all your help. Damn this forums is actually useful. Thanks fellas.
amp speakers noises
Is worth it to replace only front and rear speakers? tealio In Car Entertainment + Electronics (audio / video / alarm) 35 04-16-2010 09:11 PM
Call to those who adapted 6.5" speakers to rear of Liftback W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 9 03-10-2009 10:06 PM
Installing aftermarket componenet speakers and an amp in a LB grampi In Car Entertainment + Electronics (audio / video / alarm) 2 07-06-2007 07:49 AM
Help needed! Fitting rear Yaris Speakers ovalbuster In Car Entertainment + Electronics (audio / video / alarm) 4 06-28-2007 12:29 AM
rear speakers not loud at all? davembfan General Yaris / Vitz Discussion 16 06-20-2007 02:29 AM
