Old 10-03-2009, 01:25 PM   #1
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Neo Wedge LED's
Well it's that time again - it's getting colder, and the cheap crappy autolumination LED's I have in my A/C controls are dying one at a time. For those that don't know, last year at around the same time, my first set of LED's started to flicker one by one, and within a week all 3 were dead.
Can anyone recommend a higher quality LED that won't die in cold weather? Or am I just going to have to stock up?
devinlamothe is offline   Reply With Quote
Old 10-03-2009, 01:54 PM   #2
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Yeah...I'm bummed about this. One of my 1-week old led's already died. It seems from my reading that you need to buy high-quality leds and then solder them into the correct bases yourself.
Old 10-03-2009, 04:45 PM   #3
Split
Drives: 2008 Yaris Sedan
Question
i'm having the same problem. they're all starting to flicker now. i dont want to do any soldering, but do you have any ideas where I can get some good quality ones?
Split is offline   Reply With Quote
Old 10-03-2009, 05:30 PM   #4
MiniTRD
it's the MiniTRD
MiniTRD's Avatar
Drives: 2009 Polar White 3dr Yaris S
Send a message via MSN to MiniTRD
have you guys tried oznium?
www.oznium.com
Clark
2009 Polar White 3dr Type S
it's the miniTRD
http://www.norcalcarstyle.com/minitrd/
MiniTRD is offline   Reply With Quote
Old 10-03-2009, 07:27 PM   #5
ozmdd
ozmdd's Avatar
Thx. I'll check them out.
Old 10-03-2009, 07:57 PM   #6
devinlamothe
Thanks MiniTRD. I will check them out also.
I mean for the price, autolumination is good... they usually last around a year, but I don't really feel like replacing them that frequently.
Old 02-11-2011, 11:32 AM   #7
Split
^ i'm actually able to find the same bulbs on ebay for much cheaper than autolumination
Old 02-11-2011, 12:08 PM   #8
CAyaris
CAyaris's Avatar
Send a message via MSN to CAyaris
Are you guys using resistors cause i have had leds in my car from radio shack now for 9 months and have never had one flicker die or anything and same with the other cars i have done
108hp and still rolling
CAyaris is offline   Reply With Quote
Old 02-11-2011, 01:07 PM   #9
Vinceb
Drives: 2008 5 Speed Sedan
You shouldn't need to replace an LED each year , especially in a car where the lights aren't always on. one problem could be the soldering, if your iron is too hot, or you're keeping the heat on it for too long you may be damaging the LED.
-or-
As CAYaris said: when adding LED's to a car, you need a resistor.
You've got to look at how much current is flowing through the circuit because most LED's run on ma (milliamp's) of current. - Also LED's (unless they are specifically made to) don't flicker in a DC environment, they'd either be on (bright or dim) or off .
Vinceb is offline   Reply With Quote
What can I do with a bunch of these LEDs? eTiMaGo In Car Entertainment + Electronics (audio / video / alarm) 14 05-13-2009 04:28 PM
Neo Wedge LED for HVAC devinlamothe Cosmetic Modifications (Exterior/Interior) 2 04-03-2009 07:28 PM
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 02:07 PM
Gauge Cluster LED's Kaotic Lazagna Cosmetic Modifications (Exterior/Interior) 11 01-08-2009 12:59 AM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
