Old 10-21-2006, 01:28 AM   #1
hans_fh
New Yaris, new question ^_^
Just got my Yaris Sedan automatic transmission today. This is the first automatic transmission car I have driven. I'd like to know when I should use position N? Thanks
hans_fh is offline   Reply With Quote
Old 10-21-2006, 01:31 AM   #2
i put it in N at traffic lights, waiting to turn green... or when coasting... and letting it roll to a stop sign....
Old 10-21-2006, 01:48 AM   #3
obylium
Drives: 07 Yaris Sedan S, black/bisque
In addition to above, when your car stalls and you need to push it. That is all neutral is really useful for.
obylium is offline   Reply With Quote
Old 10-21-2006, 03:29 AM   #4
ChinoCharles
Drives: LB
The "n" stands for nitrous. Just throw it in there when you need a boost and punch it, it'll give you a 50 shot.
Old 10-21-2006, 02:00 PM   #5
swng
swng's Avatar
Drives: 06 3-dr auto RS
The 'N' position is also one of the two positions where you can start the engine, the other position being 'P', which is the more preferred positon. Don't forget to step on the brake first when you try to start the engine in 'N' although in theory a non-moving car won't suddenly move in "N' on a flat, level, and windless road. Also, start your car in 'N' only when absolutely necessary and normally only when the car is not moving.
swng is offline   Reply With Quote
Old 10-21-2006, 06:30 PM   #6
Ryu
I heard putting "N" gear to coast at some speed it might damage the transmission. Is it true or wrong?
Old 10-21-2006, 09:04 PM   #7
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Well when ur on a big hill put it on n .................weeeeeeeeeeeeeeeeee
Old 10-21-2006, 10:43 PM   #8
jeff_o
Drives: 07 Yaris
Send a message via ICQ to jeff_o Send a message via MSN to jeff_o Send a message via Yahoo to jeff_o
some people say coasting to a stop sign and putting it to N to stop is bad for the tranny.
jeff_o is offline   Reply With Quote
Old 10-22-2006, 12:33 AM   #9
obylium
I have not heard of that being bad before...
Old 10-22-2006, 01:02 AM   #10
being in N, then revving the engine and putting it into D is fun, if it lets you do that... But THAT will break down your gearbox after a while :D
Coasting in N should not cause any problems, it's like neutral in a manual transmission, no gears are engaged... Do not try to ship to P while moving to help you stop, that would also screw things up, especially as you'd have to go through R first...
But, shouldn't modern, electronically controlled automatic gearboxes prevent you from doing such naughty things? Anyone care to try?
Old 10-22-2006, 01:10 AM   #11
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
Like others said I don't think it will...if you had it in neutral and pushed on the gas peddal and then shifted into drive that wouldn't be good, its hard on the tranny, sort of like popping the clutch but for an automatic. So if you have it in neutral, shift then accelerate.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 10-25-2006, 12:15 AM   #12
Pars
Drives: 07 Yaris Liftback
Other then being towed, or trying to maximize on steering response on ice, I can't think of any other good reasons for using the neutral in an auto-tranny.
Back in the 90s, I had a Corsica (which was a great snow car) and I used to always use neutral and hand-brakes to do tricks in the snow. It was easy since I could use my thumb to snap it into neutral while pulling on the hand brakes and quickly snap back down once I release the hand-brakes. It was alot fun, being able to snap the tail around with the handbrake, letting it drift to the outside lane (since you're now facing a different direction) and meanwhile have the front wheels eat up the snow in order to pull you out from all the Gs.
Pars is offline   Reply With Quote
Old 10-25-2006, 12:18 AM   #13
KSIbucky
KSIbucky's Avatar
ya
also the "R" stands for race put it in that when you want to race
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 10-25-2006, 12:26 AM   #14
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
being in neutral and rolling to a stop puts more wear on your brakes since there is no engine braking going on. i do agree that N is fun on steep downhills...
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror
Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels
static808 is offline   Reply With Quote
Question on Yaris wheels featherz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-17-2006 10:27 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
