Old 10-10-2009, 05:31 PM   #1
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
HID brightness question
Can anyone think of a reason why one side would be brighter than the other? I just installed a Xenon Vison bixenon HID kit, and it looks good, but I'm pretty sure the Right side is less bright than the left, particularly on the Hi-beam. Is this something that could be caused by a better ground on one compared to the other?
Old 10-10-2009, 05:33 PM   #2
loose connection on the right side maybe? ballast not properly grounded? bulb not seated properly?
Old 10-10-2009, 05:39 PM   #3
ozmdd
ozmdd's Avatar
I'll do some checky-checking after dark, when I can be more definite about the intensity. Thanks, as I wanted to see if that was possible with HID's, or if they was basically "all-on" or "all-off" and the only fault could be a bad ballast or bulb. My right-side ground is not bare-metal, where the left side uses the battery-to-body ground point.
Old 10-10-2009, 05:41 PM   #4
im thinking its the ground...i did that one time w/ the hid's on my matrix xrs....fixed the ground and everything was fine.
HID question 33lam Cosmetic Modifications (Exterior/Interior) 1 08-23-2009 04:54 AM
HID kit 2009 sedan question 47_MasoN_47 Cosmetic Modifications (Exterior/Interior) 6 08-18-2009 05:26 PM
HID Question!! MurderCivic Cosmetic Modifications (Exterior/Interior) 4 01-21-2009 03:29 AM
HID question Sway84 Cosmetic Modifications (Exterior/Interior) 5 06-08-2007 10:17 AM
HID question abdiel hiram Cosmetic Modifications (Exterior/Interior) 3 02-02-2007 12:28 PM
