Old 10-14-2009, 01:31 PM   #1
127.0.0.1
Slippy storage spots solved
Hi,
I was wondering what to do with my slippery storage bins areas. You stick
anything in them and it will slide around easily.
So I was shoppin at Costco and spied a roll of this stuff
http://www.hardwareandtools.com/invt/8080483
Non adhesive, translucent, ribbed, soft contact plastic.
So I cut out a
drivers side bin,
passenger side bin,
and below the power outlet bin - sized mats, and now they stay put, and what I place on them stays put. super-sano, non adhesive, grippy. Works awesome.
Old 10-14-2009, 01:55 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
cool, can you show pictures? the link is hard to tell how thick that stuff is.
Old 10-14-2009, 02:27 PM   #3
127.0.0.1
hmmmmm...I have no pictures.
thickness is....like a clear vinyl shower curtain...a bit thicker.... and the ribs are a bit thicker
Old 10-14-2009, 02:40 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
cool, i may buy some. i have a few things that could do with this coating.
thanks for sharing!
Old 10-14-2009, 03:54 PM   #5
127.0.0.1
it is just a layer of plastic that will lay down flat and it is easy to cut.
it doesn't stick, but it does lightly grip. so if you cut out a piece to the
dimensions of the compartment or bay, it won't slide around and stuff
on it won't slide around. Watching my gps and phone, and coins, slide around
all day got boring after a while...then annoying.
You can get this stuff anywhere...the link was just to show the roll. I guess any cabinet liner would work. I got costco 'cuz it was 8 bucks for the whole roll, and I have other
things I can use that for
Old 10-14-2009, 04:58 PM   #6
frownonfun
frownonfun's Avatar
that's a good idea. i don't put much in those compartments put i do throw things in those back compartments to each side of the spare. hate hearing that stuff slide about when i have to make an abrupt stop or something. might try some of this stuff.
I crush you like tiny clown car, because you are clown, yes?
Old 10-14-2009, 05:33 PM   #7
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
This stuff works great too. You can get it practically anywhere such as Walmart, Target, hardware store or other place that sells housewares.
Blind spots jess General Yaris / Vitz Discussion 35 04-27-2016 05:14 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
Marin Storage Facility Meet (NorCal) Kioshi California 184 09-04-2009 07:18 PM
Probably a dumb question - Flat spots 33OH Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-22-2008 01:41 PM
