Old 10-15-2009, 02:11 AM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
offset for 7in on nf210s
Iv been doing some searches for Team Dynamics 15x7s, i dont know what offset i should go with. I have a 12mm spacer right now on my steelies, so i was thinking of combinations like 40mm and 12mm spacer, etc. Iv used http://www.1010tires.com/WheelOffsetCalculator.asp to help me decide. I do sometimes have about 300lbs in the back seat, and 250lb in front (me included), and if i do need to have more weight in the back, i could always swap to stock springs, shouldnt be too hard.
*whats the ratio when it comes to the stock height weight load and lowered car?
Check out my Build thread:
Old 10-15-2009, 09:16 AM   #2
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
40mm should work with that spacer. With 15x7 wheels, you should have room to work with. I run 15x7 +35mm racing wheels with 205-50-15 Kumho XS's and NF210's, and I have room to spare all the way around. Even if I had a rear spacer, it would be fine.
Old 10-15-2009, 09:18 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
if you go with +35 you'll probably rub a bit in the rear when carrying a lot of weight/passengers.
penguin garage rear camber shims would solve that.
Offset and lowering on 205/45/16s driver centric Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-13-2016 10:09 AM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
Proper offset? FA7 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-01-2009 08:37 PM
need 17inch rim guidence chino_potato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 04-09-2007 12:09 PM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 03:43 PM
