10-13-2009, 10:57 PM | #1 |
Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Aoe TigerTec..4k front, 3k rear....Tein Stech 3k front, 3.5k rear?
So one company is stiffer up front while one company is less up front but stiffer in the rear, what really is the better choice of the two? And why would they make the spring rates vary like that from front to rear?
10-14-2009, 01:10 PM | #2 |
Apexing Egg!!
personally, i like the teins better. the car seems to like more rear bias. now i used DF210's with a 23mm rear sway bar juuust fine for a long time. they are 3kgF/2.2kgR, so the tigertecs are about the same. so you could probably do either, and it wouldnt even matter, especially if you play around with tire pressure.
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
10-14-2009, 01:30 PM | #3 |
Drives: 07 Yaris Turbo Join Date: May 2007
^ agreed, and there is the price point to consider. As far as I know, the AOE TigerTecs are the best deal on springs you can get.
10-14-2009, 11:45 PM | #4 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Do the rear TigerTecs cause sagging over time?
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
10-15-2009, 09:59 AM | #5 | |
The different spring rate might just be because the car has different weight distribution from front to back. |
10-15-2009, 10:44 AM | #6 | |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
lowering spring specs for Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 03-22-2017 08:47 AM |
Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 09:03 AM |
When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
