Old 10-18-2009, 08:03 AM   #1
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
HEY Amsoil Specialist MAN - Dilemma
Here is my problem - self inflicted.
My wife has a 2005 Subaru Baja with a non turbo auto transmission.
I changed out the front differential to
75W-90 Synthetic Long Life Gear Lube (FGRQT)
and I changed the rear differential to
75W-90 Synthetic Long Life Gear Lube (FGRQT).
Here's where I went wrong:
Front capacity is 1.3 quarts
Rear is .8 quarts.
I under filled the rear by .2 quarts and over filled the front by .2 quarts.
Now I can open the front drain plug momentarily and hope it to get it to the right level, but with the rear I am stuck.
It took 6 weeks to get the 75W-90 Synthetic Long Life Gear Lube, and my wife needs the car Monday morning.
I have gotten a hold of .75 quarts (.05 quarts shy of fill up) of
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT).
HERE'S the question.
Should I drain the rear and re-fill it with what I have and leave it .05 qt under filled, Or should I just top it off with the SEVERE GEAR lube?
Anxiously awaiting your reply!
Thanks
andaconda is offline   Reply With Quote
Old 10-18-2009, 10:17 AM   #2
andaconda
andaconda's Avatar
Ah, come on -- no reply...
Waiting for response before I crawl back under it.
Old 10-18-2009, 11:54 AM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Top it off. It shouldn't be a problem.
Old 10-18-2009, 11:58 AM   #4
severous01
the drain is there as an automatic levler. or the fill i mean. you fill up the fill plug till fluid comes out, wipe clean and insert plug.
i dont see how you could have over-filled it.
but, you can use a syphon pump. walmart for under 10 bux.
Old 10-18-2009, 01:00 PM   #5
andaconda
andaconda's Avatar
Done deal....
Opened the drain plug on the front, expelled 8 oz. and refilled to top level.
On the rear, drained it all out and replaced it with the Severe Gear lube to slightly below the plug level. Didn't want to mix the two togetherl
Old 10-19-2009, 05:14 PM   #6
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Glad you figured it all out. I missed your thread over here at YW, that is if you were asking about tranny oil on Micro Image. If not disregard.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 10-20-2009, 05:41 AM   #7
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Go to an auto parts store and get a suction pump to get the over filled oil down to correct level
The Man Test *MAD DOG* Off-topic / Other Cars / Everything else Discussions 17 09-03-2009 02:28 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
Amsoil XL 5W-20 Sodium Duck DIY / Maintenance / Service 15 03-04-2009 12:19 PM
