Old 10-20-2009, 08:49 PM   #1
Sebastian18
Drives: Toyota Yaris 1.3 Xli 2008
Exclamation Need help with TEIN S-tech
Iam planning to install a set of TEIN's S-Tech on my 2009 Yaris sedan but I don't know if Iam going to have rubbing problems with my 205/50/16 tires,(offset 42,american racing Haze rims)...should I have to go down to 205/45/16 tires??I live in Peru so the roads are not that good.
Thanks, all ideas are welcome
Sebastian
Sebastian18 is offline   Reply With Quote
Old 10-20-2009, 08:57 PM   #2
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
You should be fine as long as you drive slower with that setup.
It would also help if you did a strut upgrade to minimize the bouncing, which should eliminate what's left of the rubbing issue.
Old 10-20-2009, 09:01 PM   #3
coffiend
coffiend's Avatar
Drives: 08 Black LB
If it is of any help, I'm on s techs and stock 15s w/ stock tires and stock shocks and I have only rubbed on the liner once or twice very lightly at like 50 mph on a big sharp dip.
Idk how much this really helps you but just thought I'd share my experience....
Old 10-21-2009, 12:10 AM   #4
advocate
Drives: car
I use the Tanabe DF210 lowering springs on 205/50/16 and I rub usually while pulling u-turns at low speeds.
Old 10-28-2009, 01:45 AM   #5
Sebastian18
After the advice probably I should go to down to 45īs to avoid rubbing issues...thanks for the help
Old 11-04-2009, 08:35 PM   #6
Vitz RangaaaH
Vitz RangaaaH's Avatar
I'm running on 205/45/17. You will be fine. Other then the obvious speed bumps, sharp dips no problems here.
Vitz RangaaaH is offline   Reply With Quote
07+ Yaris Tein Springs/Suspension CorSport CorSport 0 07-09-2009 01:18 PM
WTB: Tein S. Tech rear springs jkuchta Willing to Buy by private party 4 03-06-2009 02:00 PM
Springs - Tanabe DF210 or Tein S Tech andylai2k Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-10-2007 09:22 PM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
