Old 10-26-2009, 09:26 PM   #1
EBoOGie
Drives: 07 yarii
Angry Ka-Cshh.. Static!
I have a 2007 yaris sedan. Its has not been modified in any way, But when i have the RADIO on, and if i press my rear windonw defroster button, the radio cuts out and i hear static.. what gives? thanks
Erika
EBoOGie is offline   Reply With Quote
Old 10-26-2009, 09:45 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
somehow resetting the Acc circuit? Scott! Help, haha
Old 10-26-2009, 09:59 PM   #3
Lafiro
Drives: 06 Yaris Sedan
I had this problem. I recently had my rear window replaced, but before I did that, I noticed that the person who installed the tint damaged one of the lines close to the top.
After the window was replaced I have not experienced this any more.
Check every single line to make sure it is not damaged AT ALL.
Cause if it is, then that causes the interference. And if its not damaged, then it could be a bad connection between the defroster and the car, or the antenna and the car.
I really dislike this 2007 Yaris, so many problems everyone is finding with it.
Old 10-27-2009, 07:41 AM   #4
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
The radio "antenna" in our sedans is in the rear window with the defrost lines so it's probably shorting it out there.
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Old 10-27-2009, 10:50 PM   #5
Lafiro
This should be moved into the general, so everyone can see it.
I don't think its audio related, its just the effect of whatever is wrong is messing up the audio, and no one here other then me, so far has chimed in with a valid(unfortunately at my expense) fix.
Old 10-30-2009, 09:01 PM   #6
EBoOGie
Drives: 07 yarii
thanks for the reply.
i notice that it happens durin the cold season.
It would sometimes be fine in the winter.. then after a couple mins it will get static-eee.
I have turned it on durin the summer season it its fine...
Old 10-31-2009, 01:02 AM   #7
Lafiro
It should do it any time.
But mine did the exact same thing. Like I said, mine had a small amount of damage to one of the lines close to the top..
Most likely that caused the problem, and the interference? maybe its not grounding properly and something is going on? Who knows, but like I said, I got a new rear window, and no more problem thank god! One problem down, a bunch more to go :(
Solution to Static on Front Seats molinee Cosmetic Modifications (Exterior/Interior) 6 06-12-2009 06:30 PM
im tired getting static shocked!! Blenjar Off-topic / Other Cars / Everything else Discussions 19 01-30-2007 08:27 AM
