Old 10-27-2009, 11:20 PM   #1
woof
Drives: Yaris 3dr Hatch/Black
xB Gen 1 vs Yaris . . .
I was pretty happy with my xB until I looked down and noticed I had 50K miles in just 24 months. Well, I like the styling of the Yaris and saddled up with one. Both cars are five speeds and the first thing I noticed is that the Yaris' mission in life is MPG and nothing else. Not only did my xB handle 100% better, it felt much quicker.
This all comes down to final drive ratio. How feasible is it to break open the trans axle to put in a lower overall ratio gear? As I recall, the the xB was about 300 pounds heavier but still seemed to move out more quickly than my Yaris and this had to be the main difference since the drive trains are identical.
Any ideas?
woof is offline   Reply With Quote
Old 10-27-2009, 11:27 PM   #2
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
The Yaris has taller gears as you have noticed so it takes a little long between shifts. As for your question user Cali_Yaris aka "Garm" actually sway out the internal gears in his tranny to those of the 1st gen xB. The internals can be swapped but the case of the tranny is designed a little different.
Old 10-28-2009, 12:01 PM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
If you change the Yaris' transmission, then it will lose its mission in life.
Old 10-28-2009, 02:49 PM   #4
MUSKOKA800
MUSKOKA800's Avatar
Any ideas?
To improve the handling 200% add an aftermarket rear swaybar.
Old 10-28-2009, 05:43 PM   #5
severous01
get the celica or lotus six speed. then you'll get best of both worlds...double overdrive and 4 'getup gears'
Old 10-28-2009, 07:00 PM   #6
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Those transmissions are too weak!
I Drive a 129whp Yaris ;)
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
Where's the Forum Site for the First Gen Yaris?? [FR] Sébastien Loeb General Yaris / Vitz Discussion 2 02-12-2007 10:41 PM
